Question about Kids II Bright Starts Comfort_Harmony Bouncer Pastel
Broken piece in package.
I recieved this bouncy seat at my baby shower and in the middle of putting it together, I came across a broken piece. It is the piece that goes around the bar and screws the back of the seat together. I hope that's an understandable explanation.lol I don't know how else to describe it. Is there any chance that I might get a replacement piece to fix this issue? and if so, how much would this cost? Thank you for your time. Julie Johnson
Instruction how to put nania beway 123 car seat together
The two parts hanging down on the middle bottom of the back piece should snap into the slots on the base. Push down until you hear it click.
Jan 02, 2015 | Nania Baby Gear
Product # 45606 made in 1996. we have a bouncing safety first toy seat that looks like a car and the baby seats down into this middle seat. We cannot figure out how to put the polyester seat back in.
Remove the plastic ring by pushing each tab inward and pulling the top piece of the ring up. Find the buttonhole on the back of the seat and put it over the little knob. Then work the fabric around the outside of the ring, tucking it on the inside of the plastic tabs, all the way around. Then, with the talles tab at the back where the buttonhole is, line up the top half and pop it back on. The fit is very tight and the fabric will be held in place by the ring.
Aug 11, 2011 | Safety 1st First Sound Light Baby Dino...
Knob on tub spicket to release or stop shower came off
I could not find an exploded parts diagram for the Benton suite from Moen. I did find the bayhill which is very similar. Please see link below of exploded view. That should help you piece it back together.
Jul 31, 2010 | Moen & Benton& Tub & Shower Faucet
I need to replace the styrofoam form for my primo viaggio seat. I believe the part is mmsp0008
Hi, I figured I would post the outcome since I was searching for resolutions last night. I called Peg Perego. The piece that is cracked on mine (the top of the center section of the headrest) can be replaced with a new headrest piece for $32.99 (including shipping). The new piece does not have stryofoam though. It's just a heavier material (almost pillow-like). The representative that I spoke to, however, said that if the styrofoam was a clean break (meaning not in a whole bunch of pieces) it's still safe to keep it together under the cover and use the car seat as normal. Apparently, that's not what's really protecting the baby anyway. To be honest, I don't even think that I broke the styrofoam while taking the cover off, I think it was broken beforehand probably by just use and the weight of the baby. I will get some styrofoam glue and duct tape and just secure it and put my sparkly clean cover back over top of it. I think it's fine for use. Thanks and good luck to others with this issue out there!
Mar 07, 2010 | Peg Perego Primo Viaggio Verde Infant Car...
Ford ranger bench seat, broken spring under driver's side
Insert broken ends into a short piece of steel tubing or an aluminum cable crimp ( hardware store item to make a loop on wire cable) .This holds the broken ends together BUT to keep them together you need to wire the two nearest loops of the broken spring together.here's some picshttp://www.dieselgiant.com/repairseatspring.htm
Jan 15, 2010 | Baby Gear
Styrofoam insert for Peg Perego Infant Car seat
Hi, I figured I would post the outcome since I was searching for resolutions. I called Peg Perego. The piece that is cracked on my Peg Perego Primo Viaggio SIP Infant Car Seat is the top of the center section of the headrest. The representative said it can be replaced with a new headrest piece for $32.99 (including shipping). The new piece does not have stryofoam though. It's just a heavier material (almost pillow-like). The representative that I spoke to, however, said that if the styrofoam was a clean break (meaning not in a whole bunch of pieces) it's still safe to keep it together under the cover and use the car seat as normal. Apparently, that's not what's really protecting the baby anyway. To be honest, I don't even think that I broke the styrofoam while taking the cover off, I think it was broken beforehand probably by just use and the weight of the baby. I will get some styrofoam glue and duct tape and just secure it, and put my sparkly clean cover back over top of it. I think it's fine for use. Thanks and good luck to others with this issue out there!
Oct 23, 2009 | Peg Perego Primo Viaggio Verde Infant Car...
Nania car seat 3 in 1
hi, you have to apply firm downwards pressure on the backrest as it slots into booster, firstly to left side and then right
Nov 01, 2008 | Nania Topper 7540
Cosco Buckle Broken
Bought a new car seat
Sep 26, 2008 | Cosco 02-442
Putting the belts back together again.
NOT REALLY A SOLUTION BUT THE BUCKLE HAS NOW BROKEN SO WE WILL BE BUYING A NEW CAR SEAT NOW!
May 06, 2008 | Britax Baby Gear
Kids II Bright Starts Comfort_Harmony Bouncer Pastel Logo
380 people viewed this question
Top Kids II Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Kids II Baby Gear Expert? Answer questions, earn points and help others
