Question about LG 42PX5D 42 in. Plasma HDTV
Remove the back off the LG TV - LG 42PX5D 42 in. Plasma HDTV
  • DJ-Akira Shawcross
    DJ-Akira Shawcross Dec 31, 2013
    I have removed all the screws but there is a locked part on the back of the TV with a rectangular hole and a padlock sign next to it
    New Friend:
Lg 42pg20r-ta full display red color how to solve
Posted on Jan 06, 2014
HOw do I remove the base from a LG 32LK330 flat screen TV
Lay the tv screen facing down on something soft like your sette or bed so the base is hanging over the edge.
At the back you should see screws on the base, if not visible they will be under a cover which should prise off
Dec 31, 2013 | LG 32LK330 TV
My LG 42" LCD turns
first your going to need to disconnect any wires from the tv. then unplug the tv from its powersource (ex- outlet) then make sure no power is still stored within its capacitor by pressing the power button for five seconds. then lay down a plastic mat underneath the tv. then your going to need a phillips head screw driver, an allen wrench and a small rubber hammer. turn the tv around and using the screw driver remove the screws from the back of the tv, on your particular tv i believe there are 12 screws in all. carefully remove the back panel of the tv. then using the allen wrench unscrew all of the screws that hold the boards and electrical components to the front panel of the tv. remove all components from the tv. (they should all come out as one entity) now take all of the components and place on the plastic mat you have previously placed on the floor. take the rubber mallet and beat the **** out of the components and the board. once it is in snickers fun size pieces replace back onto the front panel. then carefully (without damaging any parts) put the back panel of the tv on and put the 12 screws back in place. carefully wrap the entire television in bubble wrap and personally take back to the store and order the store supervisor to refund your purchase. he will inspect the tv and showing what a horrible job that the mexicans did at the assembly facility, he will gladly give you another LG 42" and an HDMI cable for your troubles...
no, honestly go to the options menu on the tv, check o make sure its not on a sleep timer or stand by mode, if the tv has been dropped, either by you our the store in which you purchased it, it could have moved a small coil that tells the tv to turn off (makes the tv think its over-heating once it reaches a small temperature) or simply call the manufacturer and ask wtf is up.
Dec 22, 2010 | LG 42LC2D 42 in. LCD HDTV
52 inch plazma tv LG keeps turning off and each time i turn it back on it turn off sooner.if i leave it offfor long time . it comes on for 3 min. then turnes off
hi,
i think ur tvs colling fan has some problem. open the back cover of ur tv and then power it on. watch is the cooling fan is working or not. normally it will be in top the left and right side. if it is not working. remove the power. then remove the fans clean it with a brush. u can see a label on the fan in which its specification are written. remove the label. and put two drops of oil in its bearing. turn the fan leafs with ur finger for some time till it runs freely. fix it back . then power on ur tv .
ok
Dec 15, 2010 | LG Televison & Video
How to remove base so it can be wall mounted
Put LCD TV on a pillow, with screen resting on the pillow. Now the base will be free in air. Then remove screws at the back of TV, where base is joining. You might need a screw driver with magnetic head to remove screws. After removing screws, slide the base clamp out from the back of TV, and you are done.
Nov 01, 2010 | LG 32LG30 32 in. LCD HDTV
Haw to remove the base from sharp LCD TV 56 in
I find this guide about how to remove the Base of an LG LCD TV. Things You'll Need:
* Table or other flat surface
* Soft cloth or towel
* Phillips screwdriver
Instructions:
1 Unplug your LG LCD TV from its power supply and unhook any other cables from the TV.
2 Lay a towel or a soft cloth onto a table or another flat, supportive surface.
3 Lay the LG LCD TV face down on the towel, which will protect the screen from being damaged.
4 Use the Phillips screwdriver to remove the four bolts that hold the base in place. The bolts are located in the center of the TV near the bottom.
5 Slide the stand out from the bottom of the TV.
6 Press the protection cover, which is supplied with the TV, into the spot on the TV where you removed the base until you hear it click into place.
7 Re-insert the four bolts you removed into the holes on the back of the TV and tighten them with the Phillips screwdriver.
I hope this help; remember to rate this answer. Good luck.
Sep 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
I can't get the back off of an 26" LG lcd tv to check the fuses and capacitors. What is the trick to removing the back?
make sure all screws are out they need a firm pull to open the securing clips in side tv better to pull from hole were stand was
Nov 08, 2009 | LG 26LX1D 26 in. LCD HDTV
Lg 42pg20 Plasma Will not turn on
If there is no LED burning to indicate there is power than the power supply is faulty.Repair is not verry easy to do with these complicated power supply's.
Nov 02, 2009 | LG 42PG20 42 in. Plasma HDTV
Tv won't turn on
Pull Back off remove Lamp install new one Look on E-Bay for Lamps for LG DLPs
Sep 16, 2009 | LG Televison & Video
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
75 people viewed this question
Computer Repairing
Computer Repairing
