Canon Imagepress C6010VP. What does error code: E 000005-0101-05 indicate?
  • 41 Answers
SOURCE: my canon MP600 PRINTER
There's a couple things you can try:
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
If you STILL have the error code, try these two types of resets:
To clear the memory:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Good Luck!
Maggie B
Posted on Feb 23, 2008
IB4G2008
  • 3587 Answers
SOURCE: canon pixma mp600 error code 5100
try this solution..from fixmyprinter.com
This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 02, 2008
SOURCE: canon ip1880 printer service error 5202
Error 5202 means: UNRECOVERABLE ERROR. You need to return your printer to where you bought it and replace a new one if it is still under warranty.
Posted on Feb 20, 2009
bschilz
  • 2049 Answers
SOURCE: Canon printer S200SPx error code 5600
The user manual does not talk about specific error codes. From other forum I belong to, it looks like it may be a bad printhead. If that is it, Canon says to call support. I suspect the cost of a new printhead would be more than the printer is worth.
Posted on Jul 31, 2009
  • 1126 Answers
SOURCE: I have error code E000732-0001 on Canon imagepress C1
Error :
E732 code
Workaround :
E732 code is a Reader communication error.
If the Reader is disconnected from the Printer a E732 code will result. Once the Reader is disconnected the logic on the MAIN-Controller is changed to a "0". The copier is now set up to be a Printer only, and will not recognize the Reader.
To correct this, you must enter service mode, COPIER>OPTION>BODY>W/SCNR and set that to "1". Then you must turn the copier off, then on.
To enter service mode: press "Additional Functions" then "2" and "8" together, then "Additional Functions".
Which User Guide? Reference, Easy Operation Guide, Printing Guide, Mailbox Guide, Sending Guide etc....
Posted on Sep 09, 2009
I have a machine canon imagepress C6011VP with error E00000-0201-05
hi if u get error E00000 as main code that's mean the heater problem
u should have to check the hater lamp and the thermal fuse in fixing unit if every things are good this is only malfunction just reset error code.
Oct 27, 2014 | Office Equipment & Supplies
When I turn on my canon ImagePress C1+ printer it stays in warmimng up state and never gets ready. what is wrong? how can I fix it?
when i turn my conon imagepress c1 printer it state and this error code come it e00001 - 001 what the problem and how can i fix it
Nov 17, 2013 | Canon Imagepress C1 Color Copier,...
Canon ImagePress C1 cannot calibrate from Windows 7
The problem is it doesn't recognize Java 7. Install Java 6 (latest version) and it will work. You can have both Java 6 and 7 installed at the same time. As well make sure if you are running a 64bit machine you install the 32bit version of Java (so you will have 4 versions installed). Java 7 32 & 64 bit, Java 6 32 & 64 bit. I had the same issue and solved it this way.
Jul 26, 2012 | Canon Imagepress C1 Color Copier,...
Waste toner canon imagepress c1
if it is the 2nd transfer cleaning waste toner, you have to clear copier-counter-misc-2TC-Box
Jun 10, 2012 | Canon Office Equipment & Supplies
Error e020 0180 on canon imagepress c1 please give me a reply
getfile.asp?rid=1258 November 02, 2010 getfile.asp?rid=3215 Product : imagePRESS C1 / C1+ Title : E020 with Multiple Sub Codes for all Colors Problem :
Solution :
Check for a pinched or damaged wire harness from PS3 Patch sensor #2 from connector J426 back to the Side Driver p.c.b at connector J3415 and at PS7 ATR sensor from connector J209 back to the Rear Driver p.c.b. connector J3802.
getfile.asp?rid=33199
getfile.asp?rid=33201 Canon USA, Inc. Systems & Technical Support Division
Dec 19, 2010 | Canon CLC 1120 Color Copier
Canon imagepress c7000vp error code e000061-0481-05. what does it mean??
The laser shutter is faulty. The laser unit is faulty. The potential measure
Jan 16, 2010 | Office Equipment & Supplies
Canon ImagePress C1 error E000747-8000
E747 from what I remember is the connection cable from either the scanner to the print device, or scanner to the copier. Make sure that none are loose and they are in the correct slots.
Mismatching the cables may result in the error.
Dec 10, 2009 | Office Equipment & Supplies
Error :
E732 code
Workaround :
Sep 09, 2009 | Canon imageRUNNER C3200 Copier
Explanation
there is no site other than looking at the specs for each machine at canonusa.com. As for the 3170 the 70 series is just a newer version of the 3100 however I would not recomend purchasing a used 3100 they are labor intensive. And yes the CLC series is old and outdated. The imagepress is its own beast, that machine runs very well.
If you are looking at buying a used machine in the 30 page per minute range I would go with a IRc3200, 3220 same as before the 20 is just the newer one.
Jul 29, 2009 | Canon Office Equipment & Supplies
k24674
jasbo
jasbo
