Question about La Marzocco Linea Series Group 3 Espresso Machine Espresso Machine
Coffee leaking - La Marzocco Linea Series Group 3 Espresso Machine Espresso Machine
    President:
  • 1,618 Answers
Need group gaskets.
Posted on Sep 12, 2014
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
It leaks
Here is a tip that I wrote about Keurig coffee brewers and the Keurig leaking problems
Keurig One Cup Coffee Brewer leaking
heatman101
Aug 28, 2011 | Keurig B70 Coffee Maker
Coffee leaks out of the top gasket where the coffee comes out.
Use and Care guide can be found here. See Page 10 for Troubleshooting.
PROBLEM:
Coffee leaks from dispenser.
PROBABLE CAUSE
• Coffee grounds trapped in coffee tank dispensing mechanism under seal in coffee tank.
See "Cleaning with Vinegar." Refer to page 9.
Jan 31, 2011 | Hamilton Beach 48465 12-Cup Coffee Maker
Mr. Coffee CG13 12-cup coffee maker. Have used it
There is high temp tubing that may have come loose or become dammaged fromheat or the coil that heats the water may be leaking if you are using strong cleaning chemicals to remove scale from the unit. The bottom is held on with screws. Remove these and look to see what is the source of the leak.
Nov 21, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
Water leaks
unds like there is a leak in the tank. Take it back for a refund/exchange.
Jun 12, 2009 | Black & Decker TCM700 Coffee Maker
Coffee maker leaks
Please contact customer service and a seal kit can be sent to you that should fix your leak-it is successful about 90-95% of the time.
May 27, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Leaking coffee maker
Unfortunately there are many reviews for your coffee maker that are negative as far as leaking is concerned.
Most have had leaking problems about 6 months after purchasing this machine.
I don't know what to say, but you may have to bring or send it back and get another one. Maybe a different brand?
May 08, 2008 | Waring Pro WC1000 Coffee Maker
Open Questions:
Coffee Makers & Espresso Machines Logo
Top La Marzocco Coffee Makers & Espresso Machines Experts
Kelley Hopper
steve morris
steve morris
Ngoro
Ngoro
Are you a La Marzocco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
