Question about Whirlpool Washing Machines
The rinse cyle water won't drain. - Whirlpool Washing Machines
  • 5,911 Answers
For future reference, provide a MODEL number and whether or not its a FRONT loading washer, or TOP loading washer. It makes a difference in being able to diagnose a problem. If this is a top loader, this is a common problem with Whirlpool model washers, but shouldn't be a serious issue, if it's what I think it is. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 19, 2009
Cold water cutoff
Either or Both of the below may be the reason:
(1) Sensors have stopped working.
(2) Something is obstructing Drain System.
Call Customer Service Engineer.
Mar 29, 2014 | Bosch Washing Machines
Rinse cycle doesnt work
Because the water from the wash is still inside it and has not drained. So you need a new drain pump!
Jan 19, 2014 | Speed Queen AWN432 Washer
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a whirlpool washing machine fully automatic. Foe the past two days water was not pouring in the machine. Seems to be the failture of the solenoid valve.Further, when water poured inside manually,...
the drain pump may be blocked, machine wont fill if there is still some water in the system if it hasnt emptied properly. Remove the filter usualy under the panel at the front, and check for blockage and veryfy pump is running.
Jan 18, 2011 | Washing Machines
Spin cyle does not come ,but water drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Maytag PYE2300AY Electric Dryer
Kenmore model 110 23832100 stps after wash cycle before the rinse cyle. The old water has not drained.
If the machine fills, and washes and won't drain or spin out the water you need a direct drive coupling. It is located at the bottom and is on the motor shaft and consits of 3 pieces. Check this first, easy fix and not expensive.
Nov 08, 2009 | Kenmore 24032\24036 Top Load Washer
NOT DRAINING AFTER RINSE CYCLE
Dishwasher is not filling in first cycle. only in rinse cyle then it won't drain it
Jul 31, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Water will not drain after wash or rinse cyles
sjjordan96,hey just had the repair guy come today. The problem is the one way valve on the washer was clogged. Its easy to get to just remove the bottom panel of the washer and disconnect the drain hose and clear the clog.
Jan 23, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Machine will not agitate for wash or rinse cylces
that could be your problem or your drain pump maybe full... try spin and drain see if it will drain
Sep 08, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
