Question about Sharp CD-SW330 Shelf System
Reset light blinking system not coming on - Sharp CD-SW330 Shelf System
Reset my dav-ea20 system,it comes on,but shuts down with blinking light
Your unit has DC Offset(a damaged amplifier) which is why it keeps shutting down. If you are interested in repairing your Sony, please visit my website at audioserviceclinic.com. Thank you.
Jan 13, 2015 | Sony DAV-EA20 System
RESET BLINKING AIR BAG LIGHT NISSAN ALMERA 1.6
Can't -- it will just come back
The air bag is turned off for now,
until you check for SRS System Codes,
& make the required system repairs
Not read your owners manual or studied
OBD Vehicle Systems?
Oct 03, 2014 | 2005 Nissan Almera 1.6
Mitsubishi WD-73733 green blinking light will not turn on.
This is know as the blinkling light of death. You can get parts - just google TV Repair Kits
Mar 26, 2012 | Mitsubishi WD-73733 73" HDTV
How to reset change oil light in 2002 gmc envoy
On a 2002 Envoy you turn the key to run but don't start it. Then push and release the gas pedal 3 times within 5 seconds. The change engine oil light should blink for 5 seconds meaning you have reset the system. If it doesn't blink for you do the procedure again.
Feb 08, 2011 | GMC Envoy Cars & Trucks
Power will not come on even after system reset. Pushed reset and LED flashes then after it stops flashing TV will still not turn on.
do self check: when it shuts off and power light goes off:
On front of set press and hold both menu and input (device) buttons for at least five seconds and release both buttons.
Power light will blink a two digit error code, like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code and I will assist you
SD TECH
Sep 24, 2010 | Mitsubishi WS-55513 55" Rear Projection...
When i plug in my tv the screen stays black and wont come on
Hi my name is Roety,
I can help you with your issue ,
Your Mittsubishi has a system the will cause the green light to blink for 70 seconds when first plugged in, if the green light never stops blinking it is either a power supply issue or a stuck keyboard button.
So do the test and reset it to see if the light stops blinking or not.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Apr 15, 2010 | Televison & Video
Anti theft dash light is blinking on my 1998 rodeo and will not start now. Tried unhooking battery to reset, but no luck. Will not crank from jumping off either. Battery is good, all lights and the radio...
I'm assuming its an original alarm or system that came from factory or dealer. When the light blinks is because the alarm is activated. Look underneath the radio the alarm brain might be there. There will be a label on it saying alarm or security system etc. Disconnect the harness to it and try operating your vehicle.
May 03, 2009 | 1998 Isuzu Rodeo
Blinking Green Light on Mitsubishi DLP 52525
check the pico fuses on the reverse side of the DM , Just check them in circuit for continuity. let me know how you make out, and if you need any more advice lert me know
Mar 18, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Hmm I tried unplugging it for a while but I will try this again tonight since it will be unplugged for about 24 hours.
Thank you McColp for the info..
I have a service guy coming tomorrow, maybe this will work before he comes! I appreciate your help!
take care
Maria
Oct 26, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Sharp CD-SW330 Shelf System Logo
46 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
