Question about Stanley Drills
Manual for stanley ledlis - Stanley Drills
How do you load a Stanley sharpshooter TRE500
You read the manual
Stanley TRE550 Owner Manual
Or watch the videos
Stanley electric stapler/brad nailer - YouTube
? 5:06
https://www.youtube.com/watch?v=Zbgt2UXpS-M
Dec 29, 2013 - Uploaded by Tindlez
How to load staples and brad nails in Stanley electric stapler model ... I actually did not feel the instructions ...
Stanley SharpShooter Manual Staple and Brad Gun review - YouTube
? 9:35
https://www.youtube.com/watch?v=jgnqwaWYaXQ Feb 22, 2015 - Uploaded by Unpack Guy
Stanley SharpShooter Manual Staple and Brad Gun review ... The stapler is a waste of money (I just got ...
Nov 08, 2017 | Stanley Tools & Hardware - Others
Stanley flashlight keeps blinking like a strobe light how can I fix it
I assume it is an LED flashlight (you did not say). Cheap Chinese-manufactured LEDs will flicker in this way when they go bad. The condition is not repairable... you will need to replace the flashlight. (Save the batteries.)
May 11, 2015 | Stanley Camping, Backpacking & Hiking
Replace batteries for stanley 95-112 flashlight
95-112B - Stanley Tripod Flashlight battery replacement is in the center chamber. Open the three legs, then put your fingers around the bottom part of the center chamber and turn counter-clock wise. Wella put in 3 new AA Batteries.
Apr 14, 2014 | Stanley 3in1 Tripod LED Flashlight 95155
All LED's blinking, will not charge.
if there are no fuses or relay its prob defective. i would call Stanley and complain that you have had problems with it and the should replace it
Sep 18, 2013 | Stanley STA-J45C09 450 Watt Jump Starter...
How long do i have to charge the stanley j309 300 amp battery booster
Before the first use, the unit must be charged for 24 hours with a connection to an AC outlet (120V). Make sure that all of the switches are off. After that, stop charging when two red and one green LED Battery Status Indicators light.
If you are recharging the unit from a 12V battery, do not charge for more than 6 hours. (Check for a full charge by disconnecting the DC charging adapter and then press the Battery Power Level button.)
The manual for the Stanley J309 battery jump starter is available on the product page here: http://www.baccusglobal.com/stanley/j309.php . The direct link to the manual is http://www.baccusglobal.com/stanley/manuals/JUMPERS/J309%20MANUAL.pdf .
I hope this helps.
Dec 29, 2011 | Garden
How do you install the batteys in the stanley tripod legs?
To replace the batteries in each side of the 3-in-1 tripod light, you'll need to slide each light out of the central frame. Once each individual light is out on its own, you should be able to easily unscrew its bottom, giving you access to the battery compartment. Unlike the original Stanley tripod light, the actual tripod legs no longer hold the batteries.
On the original Stanley tripod LED light design, the black tripod leg tips simply unscrewed after you popped them out into the "stand" position. Much simpler to figure out.
Jun 25, 2011 | Stanley 3in1 Tripod LED Flashlight 95155
I need instuctions for the Stanley 69-702 staple gun
How do I load and use Stanley E type J nails/ tacs (0-69-708) into my Stanley 69-702 nailgun. I'm led to believe they are compatable
Aug 19, 2010 | Stanley Tools Staple/Brad Nail Gun
I have been given a stanley 95 111 flashlight. dont know how to replace batteries did not get a manual with it
You can remove either the cap or the end and replace the batteries that way. They twist counter clockwise.
Jul 19, 2010 | Stanley The Work Bostitch Security Pocket...
Drills Logo
137 people viewed this question
Top Stanley Drills Experts
Are you a Stanley Drill Expert? Answer questions, earn points and help others
