Question about Black & Decker BL10450 10 Speed Blender
Rubber drive clutch BL 3000s replacement - Black & Decker BL10450 10 Speed Blender
The buttons on my vita-mix vm0115e wont work. We have been loosing one button at a time. Was going to see if there was a loose cable or something, but I can figure out how to get the base off.
WE do not have your model here in NZ but this is how you get into our models
Remove square rubber base beaker locates onto. Remove motor driving clutch. Remove 4 screws under rubber pad you have just taken off.
Mar 28, 2014 | Vitamix Vita-Mix VM0115E 36021 Blending...
Bl 5000 replace support ring
e-mail the manufactor maybe they have some.
Jan 31, 2013 | Black & Decker BL5000 ProBlend Work Top...
How do i remove the rubber clutch of my kitchenaid blender
Grab the blade with a rag so you don't cut yourself, then grab the clutch with another rag and turn CLOCKWISE. It's threaded reverse - took me hours to figure this out. I found grabbing with rags or maybe towels worked the best. That should work
Nov 22, 2009 | KitchenAid KSB5 Ultra Power Work Top...
Kitchen Aid Blender - blade not rotating
You will definitely need to change the clutch blade i.e. the black rubber rotating bit. Chaging it on the base unit may be difficult, I would check with your local Kitcheaid repairer for spare parts and repair advice.
Also check the clutch blade on the jug itself.
Apr 01, 2009 | KitchenAid Blenders
Broken blender coupling
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
Dec 15, 2008 | Black & Decker BL600 ProBlend Work Top...
Krups 243 blender clutch wheel
These little jewels are threaded onto the motor shaft so they tighten up when in operation. To remove, you will have to immobilize the motor shaft. See if you can insert an icepick or screwdriver into the blades of the motor fan on the bottom. Then using a punch and hammer, gently tap the clutch disk in the direction opposite from its normal rotation.
BE CAREFUL not to use so much force that you break either the clutch disk or the motor fan blade.
Mar 12, 2008 | Blenders
VILLA WARE 5767
my blender jar is broken. I need to replace it
Aug 05, 2007 | VillaWare 5787 Double Smoothee Work Top...
How to replace the rubber drive in Krups 572?
it's not easy. you will need a set of pliers, a flathead screwdriver, and a phillips screwdriver. first, remove the 4 rubber plugs from the bottom of the blender (just work them out with your fingers). second, use the phillips screwdriver to unscrew the 4 screws that were under the ruber plugs. the blender should come apart. right in the bottom center on the inside of the blender you should see a steel rod with a groove in it. this rod will run all the way to the top and be connected to the rubber gear drive on top. get a firm grip on the rubber gear drive with your pliers. place the flathead screwdriver into the groove of the steel rod and unscrew. it will be very tight, but eventually, it will give. you will most likely destroy the old rubber gear drive in the process, but the idea is to replace that one anyway. good luck!
Q. Mosley
Jun 09, 2007 | Krups 572 Power Xtreme VI Work Top Blender
Black & Decker BL10450 10 Speed Blender Logo
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
