Question about Sewing Machines
Thread the Merrit 716 - Sewing Machines
Como poner el hilo en una singer merrit 4350
Download the user manual free at the Singer site under support -- it will show you with pictures how to do this.
Jun 24, 2017 | Singer Sewing Machines
I HAVE A SINGER MERRIT 8734 AND NEED TO KNOW WHAT THE NORMAL STITCH SETTING IS.
"Normal" is difficult to describe because it depends on the thread and fabric you are stitching. Standard straight stitch setting for most standard fabrics is probably whatever will deliver 10-12 stitches per inch.
Feb 05, 2017 | Singer Sewing Machines
My singer merrit 4525 sewing macine is making a squealing noise
Caveat! Oil only if your machine is mechanical. If it is computerized, follow the care instructions in the manual. The squealing could be a belt, May be best to take it for service if it continues.
Jan 25, 2017 | Singer Sewing Machines
Need instructions for singer merrit 3031
contact singer customer service about a manual and bobbiins
May 20, 2014 | Singer Sewing Machines
What size needle does the singer merrit 8734 use
here is a free downloadable manual from singer,here's the link
http://www.singerco.com/uploads/download/672_8734-8834.pdf
in the manual in the accessories it tells about the needles,
on page 7, I believe,, general sewing singer size 2020,,
& knits, stretch, elastic size 2045
plastic bobbins
Aug 30, 2012 | Singer Merritt 8734
How do I thread the Singer merritt Lock serger?
Which model is your sewing machine? There may have been several with the Merritt Lock name. The 14U44 Merrit Lock uses the same manual as the 14U44B. The manual for 14U44B UltraLock model is available from Singer here: http://www.singerco.com/uploads/download/4268b9ecf6c0ad26e8810365518e68cfea086994.pdf . See pages 10 - 17 (12- 19 of the PDF). There's also the 14U44B manual here: http://www.singerco.com/uploads/download/1292_14u44b,244b.pdf . The threading diagram is on the same pages. I'm not exactly sure which manual will help you. Additional manuals are available here: http://www.singerco.com/accessories/instruction-manuals . Enter the first part of the model number (up to any alphabetic characters). You can order copies for $15-20, depending on the machine.
I hope this helps.
Jul 18, 2012 | Sewing Machines
What is the proper way to thread a bobbin?
first go to singer website & check & see if they have a manual for the machine
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 4016) & click search
here are some other websites to check for a manual
sewingpartsonline.com
sewusa.com
the presser foot has a lever at the back of the machine or side which
lifts the presser foot, the needle move up & down when you press on the foot pedal.
May 17, 2012 | Singer Sewing Machines
The motor runs on my Singer Merrit 8734 but the needle doesn't move.
if you have to undo the clutch to wind the bobbin, then try undoing the clutch again & then retightening the clutch & see if that helps & if it doesn't help the machine needs to be checked
Mar 26, 2012 | Singer Merritt 8734
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
