Question about Parents My First Rc Car
We purchased tthe continental express TF00010513,steam does not come out of the stack like advertised and the wheels seem to slide on a hardwood floor and carpet.
Can I safely use the Shark pro Steam Pocket mop S3601 on dark hardwood floor?
You will not hurt your finish by using the steam mop...use it without any type of cleaner on the mop head and you should get a great streak free shine...
Jan 07, 2015 | Shark Vacuums
How do you remove dried gloss paint from laminate floor
Try using a steam iron, put a damp cloth on top of the paint and then the iron on top and steam the paint, it may soften it enough to get it off with a plastic scraper so you don't mar the floor finish.
Sep 10, 2014 | Stanley Laminate Hardwood Flooring Staple...
Remove mold on hardwood floor
Spray the oak floor with a 50% solution of white vinegar solution mixed with water and let stand for an hour, then clean with hot soapy water. Alternatively clean the floor with a steam mop, as either method will kill the mould on your floor.
May 24, 2014 | Shaw Solid Hardwood Floor 2 1/4" x 3/4"...
How can I prevent gaps in my hardwood floor?
There are a couple of ways to prevent gaps in your hardwood floor. Try to keep the humidity level in the room at constant 45 percent using an air conditioner or a humidifier. There is another way to prevent it, two weeks before the floor is to be laid, stack the flooring 4 bundles high leaving 7 inch space between the stacks which will allow your floor to properly acclimate.
Feb 06, 2013 | Building Materials
My h2o steam mop does not produce steam.I have only used it 6 times. I have tried using 1 part vinegar and 2 parts water to clean the system but no joy.
The H2O Mop X5 is designed to thoroughly clean floor surfaces, such as marble, ceramic, carpet, stone, linoleum, and sealed hardwood floors and parquet. Not all floor types are suitable for steam cleaning. For more details about h2o mop please visit ADS TUTORIAL
Oct 28, 2012 | Vacuums
Can I use the shark steamer on my oak hardwood floors?
Yes, it will work fine on hardwood floors...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Aug 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a Shark Steam mop and loved it for my kitchen vinyl floor. We just moved into a new home with hardwoods everywhere and I was wonder how well it worked on wood and laminated wood floors.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
It works great on hardwoods and laminate floors...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Feb 28, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I used your shark steam mop on my hardwood flooring and it took the shiny finish off, what now.
This type of problem usually is not he fault of the Shark Steam Mop.
The problem is the old residue left on the floors by other cleaners.
Here is a tip that I wrote that will help you out with that problem...
Shark Steam Pocket Mop Cleaning Problems
heatman101
Jan 05, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hardwood Floor Repair.
take a damp washcloth and a steam iron
put the damp washcloth over the dent and iron the dent with the steam iron
that should slowly raise the grain
be careful not to get the iron too hot where you scorch the floor
and work slowly, don't get in a hurry
Jan 02, 2010 | Farberware Manual Hardwood Flooring Nailer...
Orech scratching hardwood floor ???
I would recommend using another cleaning method developed for use on hardwoods. It seems to me like even if you replace the wheels, eventually they will wear down again, causing more damage to your floors. Check home depot, ask them what the recommend. Hope I could help.
Jan 27, 2009 | Oreck XL2200 Bagged Upright Vacuum
Parents My First Rc Car Logo
43 people viewed this question
Top Parents Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Parents Toy Expert? Answer questions, earn points and help others
