Question about Philips Phillips Lite-On Replacement DVD Disc Drive for Xbox 360
DVr randomly stops
Phillips blu ray disc player randomly stops and starts again, but on other discs it runs fine.
  • 1,511 Answers
The alignment head is set to read/burn disks that are true and in line with the laser beam. Some Disks, especially ones burned on other equipment may not line up correctly. Tracks may at times burn incorrectly and thus they tend to skip, very much like a phono record. Commercial discs generally are true and correct, and rarely have that problem.
Posted on Jan 07, 2014
The unit will not power up, it is plugged in to a live outlet. Is there a fuse or a reset?
FAQ: Blu-Ray, DVD and DVR / DVD Recorder ... - Toshiba
https://support.toshiba.com/support/viewContentDetail?contentId...
ToshibaApr 9, 2013 - Blu-Ray Player does not respond to some operating commands during playback; Random lock up of Blu-ray player occurring after the unit is turned off ...Check to make sure that the unit is plugged in securely to the power source (outlet,... Toshiba BD-Live enabled players offer the ability to allow different ...
PDF]BDP - S185 / BX18 - Sonyhttps://docs.sony.com/release/BDPS185_BX18.pdfSony Corporationray Disc/DVD player is harmful to eyes, do not attempt to disassemble ... Install thisunit so that the AC power cord can be ... Connect the equipment into an outlet on a circuit ... type plug has two blades and a third grounding ... Do not turn up the volume while listening to a ... protection systems used in both Blu-ray Disc™ and.[PDF]Blu-ray Disc™ / DVD Player - Manuals, Specs & Warrantyhttps://docs.sony.com/.../BDPS1200_BX120_S3200_B...Sony CorporationDVD Player. Operating ... in this Blu-ray Disc/DVD player is harmful to eyes, do not ...Install this unit so that the AC adaptor can be unplugged ... Connect the equipment into an outlet on a ... If the provided plug does not fit into your outlet .... Do not turn upthe volume while listening to a .... BD-Live™, BONUSVIEW™, and the.[PDF]Smart 3D Blu-ray Disc™ / DVD Player with Built-in .
Jan 11, 2016 | Televison & Video
Go Video DVR 5000 Says No Disc
Hi what you could try first is buying a cd lense cleaner then run this then this should remove any dust as this can cause the problem your having.
If the discs played fine before then the chances are the lense needs cleaning failing that you will probably find that the laser has stopped working but try cleaning first let me know how you get on ok
Jan 12, 2008 | GoVideo Go Video DVD/VCR Combo
NEED TO EJECT MY DVD USING THE TIME WARNER UNIVERSAL CONTROL. WHICH BUTTON IS IT?
Universal Remote codes for Blu-ray Players - AVS Forum ' Home ...
www.avsforum.com/...control.../1297068-universal-remote-codes-blu-ra...
Dec 10, 2010 - 12 posts - ‎7 authors
Brand new Sony bdp-bx59 Blu ray player with a Rogers Atlas PVR remote, Model 1056B01 ... A button, my Samsung DVD/VCR remote's Power button in there on the ... it just means the machine you are trying to control either came out after .... I have the same Blu Ray and Time Warner remote as you do.
Eject key unavailable on sony blu ray bdp-s3200 - Fixya
www.fixya.com/.../t24026716-eject_key_unavailable_sony_blu_ray_bd...
Apr 6, 2014 - eject key unavailable on sony blu ray bdp-s3200 disk tray wont open -Sony BDP-S3200 ... Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 4 Answers .... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? ... Sony BDP-S300 tray open while updating, stuck here.
How can I fix my Sony Blu-Ray player BDP-S3200 with the ...
www.fixya.com/.../t24578583-fix_sony_blu_ray_player_bdp_s3200_eje...
Jul 27, 2010 - Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 1 Answer .... SOURCE: Sony BDP-S300 won't play any Blu Ray discs. Sounds ... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? Dec 28 ...My player cant eject disc; it say '' eject key is not available this time''.
Remote codes - Comcast Help and Support Forums
Nov 23, 2013 | Sony BDP-S300 Blu-Ray Disc Player
Are blu ray stops payling in the middle of movies for no apparent reason
One of the possible reasons is that your Blu-ray player is unable to read the disc. Check to make sure the inserted disc is clean and not scratched on the playing side. If so clean the surface of the disc or use an alternative Blu-ray disc to verify. ... Only Region B Blu-ray discs and Region 4 DVDs are compatible.11 Oct 2017
Blu-ray Player cannot play discs - Samsung
www.samsung.com/au/support/skp/faq/1045337 blu ray stops payling Google Search
Oct 23, 2017 | Sharp BDHP20U Blu-Ray Player
Cant play 2012 on my phillips blu-ray bdp 3000 player
try other disc.if other disc working fine. some disc no play then there is problem lens assy.
Oct 17, 2010 | Philips BDP7200/37 Blu-Ray Player
My phillips dvp5140/37. video player ,stops
Does the player ask for a password?
If it does look in the manual or contact Philips on their website.
This helped me a lot once.
Jun 13, 2010 | Philips DVP5140/37 DVD Player
Bought terminator salvation wont play past titles little logo comes up on left side of screen no explanation in booklet with dvd player other dvd play ok help
i had the same trouble with my LG blu ray . you need to upgrade your software on your blu ray. if u email Phillips customer service and ask for the link to upgrade ( which is called firmware ) the u can download it and put it on a disc . once you put the disc in the player it will update for you, see how u go
Dec 04, 2009 | Philips BDP9000 Blu-Ray Disc Player
Blu-ray discs all of the sudden incompatible and won't play
Look for a firmware upgrade for your player. They exist for sole purpose of increasing compatibility with newer blu ray releases. If that does not do the trick it appears that your player's laser assembly is losing its ability to focus on the disk(s). Repair is not cost effective and you will have to go shopping.
Mar 31, 2017 | Sharp AQUOS Blu-ray Disc Player
Phillips portable player PET724
I had the same problem with my PET724. I tried cleaning the lens, letting the battery run dead, even beating on it but nothing worked. When I was cleaning the lens again with some cleaning agent I accidentally slid the laser head as far away from the center as it would go. When I loaded another disc it has worked fine ever since. I have played at least two dozen discs so far with no problem.
Hope this helps.
Apr 19, 2008 | Philips PET724 Portable DVD Player
Philips Phillips Lite-On Replacement DVD Disc Drive for Xbox 360 Logo
49 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
