Question about Gateway LT4004u Atom N2600 1.6GHz Dual-Core 1GB 250GB 10.1" - $261.69
Screen resolution too low
Does not allow to run the softwares from the windows statup screen
  • Josh Schaffran Dec 29, 2013
    Hi Josu? Maldonado, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    What software are you attempting to run?
    what is your current resolution set to?
Posted on Dec 29, 2013
The text on my pc keeps going blue, how can I stop it?
Windows allows you to change the themes of your computer. This includes the wallpaper, the screensaver when your computer is idle, any noises it makes, and even the color of the toolbars and windows. Sometimes, however, when you restart your computer, the theme will revert back to the Windows default theme, which is called Aero. This can be because you have not disabled Aero, because your performance settings are using too much energy, or because your screen resolution is too high or low for the theme you are using.
Screen Resolution b> The higher your screen resolution, the sharper the images and text will appear. Sometimes, however, the of the wallpaper for the theme is not the same as the screen resolution. This can cause your theme to revert back to the default. To fix this, click the "Start" button. Then click "Control Panel." In the "Control Panel" window click "Adjust Screen Resolution" under "Appearance and Personalization." Select the resolution that is the same as your wallpaper. b> Performance Settings b> If your computer is running on high performance settings, your computer's energy will be used quickly and Windows may automatically change the screen saver to keep the energy from running to low. To change your performance settings, open the "Control Panel" and click "System and Security." Then click "Change Battery Settings" under "Power Options" and select "Power Saver" or "Balance." b> Disable Aero b> Aero is the default theme setting for Windows Vista and Windows 7. If you try to change your theme and it reverts back to Aero, it is because Aero is still not disabled. To disable Aero, right-click on your desktop and click "Personalize." A window of all the themes on your computer will open. You will see "My Themes," which are any themes you have created, and "Aero Themes" under it. To disable Aero, click "Save Theme" under "My Themes" to make your current settings default, or select one of the themes under "My Themes." This will make that theme the default. b> Troubleshooter b> If you still cannot figure out why Windows changes the theme back to the default after restarting, you can use Windows's built-in troubleshooter. The troubleshooter will find the source of the problem and automatically fix it for you. To use the troubleshooter for your theme, open the "Control Panel" and click "System and Security." Then click "Troubleshoot Common Problems." Under "Action Center," select "Appearance and Personalization." The troubleshooter will run. When you restart after it completes its action, your theme should stay the same. Hope this helps.
b>
Dec 15, 2012 | Computers & Internet
I want to change the resolution on my computer screen to 1280 x 1024
Right click anywhere on your desktop and from the pop up menu select Screen Resolution. It will open the screen for you to adjust the resolution by selecting the pull down arrow at Resolution, it should open a screen with a slider that will allow you to choose a variety of resolutions. (If you are not running a PC with Windows 7 to drive the monitor, you will need a different solution)
Sep 30, 2012 | Computers & Internet
Very dark screen in full screen mode
Check the monitors native resolution (you can get it in their website's technical specification area and set the same resolution in your windows resolution.
Jul 22, 2012 | Dell Dimension 8400 PC Desktop
How do i get my computer out of the resolution mode?
Apparently the monitor screen resolution setting is not correct. Screen resolution stays up until it is corrected.
Either the setting is off in Windows, or you have been changing the monitor settings, with the monitor.
WinXP:
Right-click on an empty area of your desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on the Settings tab.
Go down to where it states Screen Resolution.
What is the pixel setting? For example mine states 1600 x 900 pixels.
I am running dual monitors, and this is the correct screen resolution for the Primary monitor.
If it wasn't I would Left-click on the Slider, hold the left mouse button down, and slide the Slider to the correct native resolution.
(Under Screen Resolution is a line. To the left it states - Less
To the right of the line it states - More
The Slider is the rectangular down arrow on the line )
ALSO;
Under the Color quality heading, make sure in the box under it, that it states - Highest (32 bit)
IF not, left-click on the blue down arrow to the right.
Then left-click right on - Highest (32 bit)
How to know what is the native resolution for your monitor?
Look at the manufacturer name, and the model number on the back.
Type this information in your browser search bar, then click on the search icon.
Look for Specifications.
If you changed the screen resolution settings with the monitor, press the Menu button. The screen should go off.
ALSO, with a new monitor there is an Installation CD Disk, provided with it.
This disk MUST be used. It has the drivers for the monitor on it.
[ Drivers: Small pieces of software that allow the Operating System to 'communicate' with a device.
The monitor is a Device.
Windows XP, and Windows 7 are two examples of an O/S.
Operating System ]
If you have Vista or Windows 7, post in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 11, 2012 | Dell Computers & Internet
My computer's screen resolution is too low
Hello to adjust your screen resolution, right click on the desktop and either click properties for Windows XP or screen resolution for Windows Vista/7. Then for XP click settings and you will see a slider bar where you can adjust your screen resolution. For windows 7, it will be on the screen that opens up, just slide the bar into the resolution you want.
Thanks for using FixYa!
Aug 15, 2011 | Computers & Internet
Windows 7 screen goes to large resolution and needs reset on startup.
Turn on the PC. Press F8 at booting into windows 7. It will display  many options
Select the Enable low resolution video(640x480) then login to system.
then change the resolution as required
Right click on a empty space on the desktop and click on Screen Resolution.
Enable low resolution video (640 × 480)
Jun 08, 2011 | AOC 718Swag-1 LCD Monitor
The Screen turns black when I attempt to start windows normally. It sounds like windows is starting, but nothing appears on the screen
It sounds like windows has been set to a screen resolution beyond the limits of the capabilities of the built in LCD. Luckily windows has a menu that allows you to change to a highly compatible low resolution mode. To select this mode, start tapping the [F8] key just after the HP/Compaq screen when the computer switches on. Hopefully if you pushed the button in time, you should be presented with a menu. Use the up and down arrows on the keyboard to select the option that says either "Enable VGA Mode" or "Enable Low Resolution Video (640x480)".
Windows should now load, but everything will look extra large. To fix this, go into your display properties (right click on desktop and select either "properties" or "screen resolution"), and choose the recommended screen resolution.
Dec 24, 2010 | Compaq Presario CQ60-220US PC Laptop
Can't click Accept in Software License Agreement dialog box in Ad
This is a simple work around, but it worked for me. Create a new user and make that account the Administrator. Log in with the new account an then run Adobe and click Accept. Some reason this worked for me. Good Luck.
May 17, 2009 | Adobe Acrobat 7.0 Professional
Everything on the screen is enlarged?
You should be able to reset you screen resolution by clicking on Display inside the control panel. Go to the Settings tab once the display properties window opens and look for the screen resolution area that allows you to adjust the resolution. If its set at the low end, move it over to the high end and press Apply to test out the new sizing
Mar 26, 2009 | HP Pavilion dv6000z Notebook
I just bought a Canon d750. When I went to install the software it told me that the screen resolution to execute digital camera disk is not suffcient. I'm running Windows XP, and there shouldn't be a...
The operating system is not relevent to the screen resolution. This can be set from very low to the maximum that the monitor and display card combination can handle.
If you cannot achieve the proper resolution on your computer, it is possible that the display card and monitor combination may be not up to date to work with the camera software.
You have to make sure that the screen resolution is set to the minimum setting as recomended by the manufacture.
You can find the settings in the screen settings properties. Refer to the installation instructions for details.
Jerry G.
Jul 12, 2008 | Canon Cameras
Gateway LT4004u Atom N2600 1.6GHz Dual-Core 1GB 250GB 10.1" - $261.69 Logo
20 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
