Question about everbuying Cheap Unlocked Phone 4 inch Goophone P5 Android 4.2 3G Smart Phone MTK6577 Dual Core 1GHz 2GB RAM 16GB ROM WSVGA Screen 8MP Camera GPS WiFi White
My backlight would'nt stay on from the goophnoe p5
Hi I have a Acer aspire 9410 (9414wlsmi) 17 screen. The problem is that i have no backlight at all, i've bought a new screen + new inverter/backlight driver + new cable but it did'nt help i have...
The inverter/backlight combination isn't the whole picture. The inverter powers the backlight, but the inverter is controlled by a signal commonly called "Brite-On", which comes from the motherboard. If the "Bright -On" signal from the motherboard is missing,then the inverter (and thus the backlight) won't work. The problem you are having is on the motherboard. here's a link to a datasheet of such a device:
http://pdf1.alldatasheet.com/datasheet-pdf/view/245132/FAIRCHILD/FAN7317.html
May 15, 2011 | Acer Aspire 3690 (LX.AFL0J.044) PC...
Have a p5 code souns like condensate pump stays on all the time.
what kind of unit it is? brand model. most models dont have pumps? do you mean the compressor
Nov 10, 2010 | Heating & Cooling
Whirlpool error code F50 who do I call ?
F50 means that the Rotation Position Sensor doesn't sense any movement from the motor.
This test checks the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. NOTE: Drain water from tub.
1. Unplug washer or disconnect power.
2. Check to see if basket will turn freely.If basket turns freely, go to step 3. If basket does not turn freely, determine what is causing the mechanical friction or lock up.
3. Remove the console to access the machine/motor control assembly.
4. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 5. If visual checks fail, reconnect P5 and P10.
5. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3.Also measure the resistance at the P10 connector between pins P10-1and P10-7 and verify that the resistance is within the range. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range.
6. Tilt machine forward to access the bottom of the machine and the drive motor area. Remove the motor bolt, then the motor cover to access the motor connections.
7. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check fails,reconnect the electrical connections, reassemble stator and motor cover.
8. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector.If there is no continuity,replace the lower machine harness.
9. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector.If there is continuity, replace the drive motor.If there is no continuity, replace the lower machine harness.
10. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test.
11. If the Diagnostics motor failed, then the machine/motor control has failed: Unplug the washer or disconnect power.Replace the machine/motor control assembly.
Thank you !!
Aug 12, 2010 | Washing Machines
Error message F50
Thank you !!
Jun 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Philips GoGear HDD086/05 backlight will not stay on
go to the settings on the mp3, go to backlight and set light to "always on".
May 20, 2009 | Philips GOGEAR SA6045 MP3 Player
I was chaging setting and I turned of backlight
If its just the backlight then you can stay in a well lit area and look at the screen that way to change the setting, also you could try plugging it in to keep the backlight on.
May 19, 2009 | Nokia 1600 Cellular Phone
Dell monitor 15 inch the green light stays on but no picture
It's the backlight supply tripping out from backlight failure, but the thing still stays on. I got it to act right by switching to factory presets with some fast menu action once, but the general solution is going to involve tricking the backlight into staying on; you can look at the thing in bright ambient light to see that the display is still working, but of course without a backlight it's pretty much useless.
Since $100 buys a better and more efficient monitor, just replace it; otherwise of course you can either replace the backlight (or go for one of the projector mods) or convince its drive circuit to put up with it a bit longer. I spotted a bad capacitor but swapping that out hasn't gone well yet....
Mar 14, 2009 | Dell E153FP 15" LCD Monitor
Error condition
Have you tried to reset the printers defaults?
Aug 13, 2008 | Zebra 170XiIIIPlus Thermal Label Printer
everbuying Cheap Unlocked Phone 4 inch Goophone P5 Android 4.2 3G Smart Phone MTK6577 Dual Core 1GHz 2GB RAM 16GB ROM WSVGA Screen 8MP Camera GPS WiFi White Logo
65 people viewed this question
Top everbuying Video Game Consoles & Games Experts
James Wishart
Are you an everbuying Video Game Console and Game Expert? Answer questions, earn points and help others
