Question about Gear Head mp2850blk mp2850blk
LAPTOP DOESNT LOAD MOUSE OR RECEIVER DRIVERS - Gear Head mp2850blk mp2850blk
    Problem Solver:
  • 12 Answers
Try google'ing the mouse drivers.
Posted on Dec 29, 2013
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
How to install wirless mouse
It depends on the wireless technology used by the mouse.
1. Infrared
If your mouse used Infrared for communicating with your PC, you will have to place an Infrared receiver on your desk, in line with the mouse you want to install. You will definitely have to install the drivers supplied with the mouse/Infrared receiver.
2. Bluetooth
If the mouse uses Bluetooth, first you either will have to install a Bluetooth dongle on your PC/Laptop (if it doesn't have Bluetooth integrated) or activate the Bluetooth on your PC/Laptop. Then, using the Bluetooth software supplied with the dongle or PC/Laptop, search for new devices and choose the mouse to pair with. You may have to install the software provided with the mouse for if to work.
May 09, 2011 | Computers & Internet
Mouse model 1007 does not work. lights are both lit one on mouse one on receiver but cursor doesnt move. hit the connect button and still nothing. Your help would be greatly appreciated.
Remove the battery and put it back again
Try plugging the receiver in a new USB port and install the drivers again. If it is already installed, make sure the Mouse is being detected by viewing it in Device manager.
After following the above steps, you can press the connect button to sync up with the receiver.
The issue can most probably be related to corrupted/hang drivers so you can try restarting the computer and changing USB slot for receiver.
Mar 12, 2011 | Microsoft Wireless IntelliMouse Explorer
My Trust MI-4150K mouse doesnt move anymore. I've tried to change battery, changed port usb of the receiver, changed PC and still doesnt work. please help. It may have something with the reset button.
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty or you
make sure you have the correct mouse selected control panel mouse hardware
might have to uninstall the drivers then reinstall the drivers
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Dec 03, 2010 | Computers & Internet
I CANT USE MY NEW MOUSE PS 2 GENIUS XSCROLL .
It doesn't need any drivers. Plug the receiver in a different USB socket, wait until the system finds it, and then pair the mouse and the receiver using "connect" buttons on both as instructed in the manual.
Dec 06, 2009 | Logitech Cordless Mouse
Does the wireless mouse receiver has battery?
you need to chean the recivers motherboard only thenn it will work but dont try that whit othermouses because thet type of error has only that mouse
Nov 18, 2009 | Logitech Cordless Mouse
Cant use mouse on laptop, says installed drivers
if ur driver is ok, then u try first to restart ur system or properly shut down ur laptop them plug ur mouse carefully.........
Nov 10, 2009 | AOpen O-75B 3D Black Optical Wheel Mouse,...
Kennsington 72216 mouse continuosly clicking after changing batte
try installing the software that came with the mouse. if none came with it then go to the manufacturers website and down load the drivers. if none available then there might be something physically wrong with the mouse and you replace it.
Feb 28, 2009 | Kensington PilotMouse Optical Wireless...
Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Jan 22, 2009 | Dynex Wireless Keyboard/Optical Mouse...
It doesnt work...
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Apr 09, 2008 | Razer DeathAdder RZ01-00150100-R2M1
Gear Head mp2850blk mp2850blk Logo
53 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
brian soufane
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
