Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Wall oven stopped working
My oven stopped working it is only displaying a 1 in the display. My husband thinks water leaked from kettle into the control panel. Does anyone know how to fix this?
  • Official Brand Answer
  • 4,342 Answers
Good Morning Peggy, thank you for allowing me to assist you!
Typically error code F1 indicates that your range has detected an issue with the runaway temperature (overheating). Try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) will need replacing. Hopes this help!
Posted on Jan 06, 2014
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
    Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
    Posted on Nov 13, 2012
    localwonder
    • 6784 Answers
    SOURCE: Control panel on oven not working (clock/heat time, etc..) (model fgf326a)
    HI, this control(clock/timer), will need to be replaced at this time. this code represent a control fault within the chip set(logic). this control has failed.
    Posted on Jun 01, 2009
    • 87 Answers
    SOURCE: Oven Problem
    Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
    Posted on Jun 08, 2007
    SOURCE: I have a Frigidaire 30" self cleaning oven that is a stand alone...the oven stopped working this past weekend
    have your electronic timer sent for repairs, go on internet at ApplianceTomers.com
    Posted on Nov 11, 2008
    SOURCE: Instructions for Frigidaire oven missing.
    I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
    Posted on Dec 03, 2008
    Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
    These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
    There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
    Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
    Jul 06, 2011 | New World Ovens
    My oven display has "sABBATH" written on the
    May I get the make and model # to help you more. On some ovens if you hold the clock button for secondes it should turn off. I need the make and model # to be-sure.
    Apr 24, 2011 | Maytag 24" Built-In Single Electric Wall...
    Thermador CM301U Microwave cook smart, self clean and proof buttons all make the display light up as normal, but probe, convection, bake, broil and roast do not. I can hear the beep but nothing on the...
    there are two boards in the oven and i would think that it is the one on the left called the secondary . if you remove the display panel you will find the tech sheet and this should help diag the problem . thermador does use fault code's and if any have displayed / in the tech sheet you will be able to tell whats going on or in this case what isn't .. mm hope this helps .. feed back pls .
    Nov 29, 2010 | Thermador CM301U Electric Single Oven
    Kitchenaid double digital convection conversion oven keypad went out. Any ideas on the problem. Electric panel circuit breakers are okay. Sharon C.
    I think these use the same controller board as the Jenn-air units, they have a weak capacitor (C3) on the control board (Timer/control Display). Remove the top panel and look for a discolored or leaking capacitor (usually black about 1/2" high 3/8" in accross). Replace the capacitor and the problem goes away, until next time you use the self clean cycle which seems to overheat the control board and ruin the capacitor.
    Sep 23, 2009 | Electrolux 30" Built-In Double Electric...
    F8 / Convection portion of top oven doesn't work
    F8 Oven door lock failure Check lock relay and door switches.
    Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
    my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
    Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Whirlpool electric oven
    hi switch main power off at wall. hold middle clock button in and switch power back on at the wall. Display should show --:-- and oven should work.
    Nov 30, 2007 | Ovens
    Problems with Jenn-Air Electric Double-Wall Oven
    that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
    Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
    Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
    83 people viewed this question
    Top Frigidaire Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Sal DeAngelo
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
