Question about Cisco Air-Ap1131G-A-K9 - Aironet 1131G Wireless Access Point - 54Mbps
How to configure cisco aironet 1131 and how to find the getaway for this router ?
I wanna reset this router and reconfigure this router,i don,t know how to find the getway and how to configure this router,by console cable
    Scholar:
  • 112 Answers
Have you read the quick start and installation guides?
http://www.cisco.com/en/US/products/ps6087/prod_installation_guides_list.html
Yes, the AP should be able to obtain an IP address via DHCP from your
Netopia router.
If this device is used, it may not be setup to aquire things via DHCP,
and you'll probably have to hookup over a console port and do password
recovery.
Cisco's aren't the easiest things to setup, they are more akin to a
box of tools, rather than a single purpose built item, and thus can
do quitealot, but you have to learn how to use the tool first. It will
then let you setup things quite advanced that the single-purpose built
item never imagined, but you have to know how to get there first, not
coast and do the advanced stuff later.
Posted on Feb 03, 2014
4 Suggested Answers
  • 5 Answers
SOURCE: configure cisco aironet wifi
if ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Posted on Jun 19, 2008
SOURCE: how to reset Cisco Aironet 340 Wireless bridge?
Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
    For more information, refer to the Cabling Guide for Console and AUX Ports.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal. Other programs are similar.
  3. Enter a name in the Connection Description window.
  4. Select an icon for the connection.
  5. Click OK.
  6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
  7. Click OK.
  8. In the Port Settings window, make these selections:
    • Bits per second (baud): 9600
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
    • Flow Control: None
  9. Click OK.
  10. In the Connection Description window, enter a name and select an icon for the connection.
  11. Click OK.
  12. Press Enter.
  13. When the Main Menu screen appears, reboot the bridge.
    Turn the unit off and then back on.
  14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
  15. Press Enter.
  16. Enter Yes.
  17. Press Enter in order to confirm the command.
  18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
see this link 340 Wireless Bridge
Posted on Jul 25, 2008
  • 54 Answers
SOURCE: there is issue of low signal strength showing in
Signal strength can have a lot to do with where the router is compaired to where you sit at your pc/ laptop. If you have a house with thick walls you should go for a N type router rather than the G (standard router type). but a simple way to boost signal is to put a pice of tinfoil behind the anntenae of the router, directing the signal to where your computer is and not letting it just dissipate into the walls of the house in all directions.
hope this helps, but remessage if I have not been clear enough ;)
Posted on Oct 07, 2010
Can get router to work
The Cisco Aironet 1200 access point provides secure wireless connection to your network. Cisco's wireless access design meet the needs of a small to medium size business.
This unit provides secure network access for laptops or Wi-Fi capable portable devices, which you upgrade at any time as your business grows.
A beneficial feature of the Cisco Aironet 1200 is its ability for the administrator to reset the access point remotely.
This resetting process works through your internet browser.
Log on to the System Configuration page by entering your Cisco Airnet 1200 IP address in your browsers web address text box.
Enter your user and password information from the pop up menu.
Click on the "Setup" button from the summary status page.
Select the "Cisco Services" setup option and click on "Manage System Configuration."
Click on "Reset All System Factory Defaults" to reset the router.
The Cisco Aironet 1200 will be restored to factory defaults.
http://www.cisco.com/en/US/products/hw/wireless/ps430/index.htmlCisco Aironet 1200 Series
Configaration Cisco Aironet 1200 Serieshttp://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html - wp1016665
May 07, 2014 | Linksys Cisco Aironet 1200 Wireless Access...
Aironet 1410
look for the rest button - press & hold it for 10 secs. - all lights must flash before u let go
Sep 17, 2008 | Cisco Aironet 1410 802.11a...
Reset cisco aironet 350 adapter
Try Putty and a 9pin male to RJ45 RS232 serial console cable.
the instructions are in the link provided here:
http://wirelesslanprofessionals.com/wp-content/uploads/2010/01/Password-Recovery-on-Cisco-APs.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Jun 30, 2017 | Computers & Internet
How to reset the 1131 Cisco AP manually.
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
There a great article at General Router Setup.
Jan 24, 2011 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
There is issue of low signal strength showing in Cisco Aironet 1131. how to resolve it?
Oct 07, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
How do I return the default configuration
www.mikrotik.com/testdocs/ros/2.9/interface/aironet.pdf
Maunal above, usually, at the rear is a small hole, you insert something into the hole and push the button, with the power removed. This resets the router, and next time you try to login, it will be at the default, login, and Password, ALL settings will be returned to as it was when first used.
Apr 23, 2010 | Aironet Cisco AP4800
Default username & password after hard reset
Username:[none]
Password:Cisco or
:root
:Cisco or
:Cisco
:Cisco
Try from above 3 then you can access cisco router.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 01, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Can't connect to my Cisco Aironet 350 wireless Access Point
Did you setup and configure your Cisco aironet 350 directly from your laptop? I would verify the IP configuration on your laptop and make sure that your Default Gateway and subnet mask and DNS are set correctly. Give it a static address on the same subnet and see if it can see the router. Hope that helps!
Cheers!
J the Guru
Sep 09, 2017 | Cisco Aironet 350 Series Wireless...
Dose cisco aironet 1100 support routing
You must use a router to perform NATing to the ISP. Simply use a Netgear or Linksys router and plug your access point into it. You can even use a Netgear or Linksys wireless router with the ethernet ports built into it. Just disable the onboard wireless.
Jul 31, 2008 | Cisco (airap1120bak9airpcm352) 802.11b
How to reset Cisco Aironet 340 Wireless bridge?
  5. Click OK.
  7. Click OK.
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
  9. Click OK.
  11. Click OK.
  12. Press Enter.
  15. Press Enter.
  16. Enter Yes.
Jul 22, 2008 | Cisco Aironet 340 Wireless Bridge
Cisco Air-Ap1131G-A-K9 - Aironet 1131G Wireless Access Point - 54Mbps Logo
152 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
