Question about RCA RTD317W Theater System
Rca rtd317w no sound
No sound coming from speakers or RCA port. There is a short cackling sound before it cuts off.
IB4G2008
  • 3587 Answers
SOURCE: RCA RT2760 problem
sounds like you may have blown the internal amplifier circuit.you a handy sort of person?
Posted on Apr 20, 2008
  • 899 Answers
SOURCE: when i unplug my rca rt2250 home theater system.
this is the amp IC and while unplugging and plugging it in again helps reset the IC for a little while , it will eventually completely quit and will need replaced
make sure that none of the speaker wires(bare wires) are touching or look like they might be where they are connected at
also if turning up the volume makes it cut out or sound bad then this will also indicate a bad amp IC
Posted on Mar 12, 2009
SOURCE: No Sound
All i get from my speakers is a humming sound, what do i do
Posted on Jun 19, 2009
muntejaya
  • 10421 Answers
SOURCE: multi region code for RCA
Please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__8754r
Posted on Feb 27, 2011
dunnbiker
  • 8546 Answers
SOURCE: could i use a universal remote on a rca rtd317w
Sure if it supports RCA products. That would be up to the remote's designers and the codes would be in its documentation or maybe on their website.
Posted on Sep 22, 2011
Why won't it turn on?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 05, 2015 | RCA RTD317W Theater System
I am getting no sound from my rtd317w. Previously I was i don't know what happened
I think they are just junk. Speakers might be ok for awhile but this system is junk.
Aug 12, 2012 | RCA RTD317W Theater System
No sound coming from center channel speaker
check surround sound settings, or another channel" this is your voice speaker, or hook one of the other speakers up to the center channel to see if that center speaker is good , you can also use a battery like a 9 volt to test the center speaker just touch it to the speaker wire momentary. and listen for a cackling noise if it makes a noise it is more than likely good
May 29, 2012 | RCA Rtd317w 5.1 Channel Home Theater...
Could i use a universal remote on a rca rtd317w home theater system
Sep 22, 2011 | RCA RTD317W Theater System
The audio keeps going in and out and cuts off. Also I have other devices going into aux in but it doesn't show 5.1 surround it only shows the front L, Front R, and CT speakers in stereo. I want everything...
If you are playing a source that is Stereo such as FM Radio or a CD the sound will not use all 5.1 speakers unless you enable the correct Surround Mode. On the remote there is a button on the lower right of the remote that says SURROUND. You can toggle through the various surround modes with this button the mode you want is Dolby Pro Logic The Pro Logic mode uses the built-in circuit to steer the Left, Center, Right and Mono Surround channel audio signals and uses all five speakers to play both stereo and Dolby Pro Logic program source, such as TV and VCR. You can use this mode with any stereo program source (such as VCR/TV) to enjoy multi-channel sound experience.
Mar 02, 2011 | RCA RTD317W Theater System
RCA Model RTD317W The standby mode (blue light) is on. But when you try to turn the system on by remote or on front of the theater itself it goes off and does nothing. The only way to get the standby...
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 04, 2011 | RCA RTD317W Theater System
RCA RTD317W Theater System Logo
55 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
