Question about Yamaha Music
Piano roll out manual z30258-bs
Silver crest roll out piano z30258-bs
Service manual for the roland piano kr375
Your best bet would be to contact Roland directly to obtain a service manual. Go to the Support link at the top of this page- Roland
Jan 15, 2015 | Roland Music
Owner's manual for a sharper image play n roll piano
I know someone else with the same problem - did you ever find one anywhere?
Jun 02, 2012 | Sharper Image Play N Roll Piano
Midi settings
You have to plug in the laptop sorry to say. Think of it as a piano that can be used as a midi controller.
Jan 29, 2012 | Williams Allegro 88-Key Digital Piano
4 keys do not work on Play and Roll Piano
There MAY be a break in the flexible conductors going to the keys... probably not repairable I am afraid.
Apr 26, 2011 | Sharper Image Play N Roll Piano
My kimball electromatic player piano won't automatically rewind, or even stop, when it reaches the end of the roll. It just keeps going and pulls the tape off the roller. If I press the stop button, it...
Look near the end of the roll for a hole or other trigger method that triggers the stop. It could be a hole in just one column or possibly a heavy mark on the roll. The later would be sensed by an optical pickup which MIGHT have a lamp burned out. From the site:
http://www.player-care.com/system55.html
It appears that vacumn via holes triggers the stop and the rewind by "pouch" switches. I suspect those swithches trigger and lock the relays in the same pix at the site.
First thing to do is to see if those switches actuate at the end of the roll so as to stop and then rewind.
Aug 28, 2010 | Music
Wurlizter player piano roll turns but no sound
Is the vacuum pump working? Most players are actuated by a vacumm system which must be working to drive the hammers.
Mar 20, 2010 | Music
I'm in the studio using LogicPro with my MO8 -
In General MIDI, the grand piano is defaulted to MIDI channel 1.
IF you have a device that responds to "General MIDI" format, just send the MIDI data to channel one and you should be fine. Remember that pianos are VELOCITY controlled and usually don't use after touch so you have to generate appropriate velocity for EACH note if you are using an editor.
Jan 07, 2010 | Yamaha Music
I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Oct 05, 2009 | Roland Music
I need a service manual for Roland FP8 piano, or..
Did you ever get hold of an FP-8 service manual? The weight replacement is relatively simple: The case opens by removal of eight screws, four at each end on the underside. The top then hinges up. Keyboard assembly is removed by first unplugging the two white ribbon connectors at the center, then removing the screws at the front edge (underneath) and the screws (gold) at the back of the assembly (accessible from the top). Keys pop out by spreading the two "wings" at the pivot point, and then the weights (Roland calls them "hammers") lift out. Roland will sell you new ones, but I have no idea whether the replacements are any better than the originals. I've done two of these pianos so far, and have a third waiting to be worked on. I do have a service manual, but I think I downloaded it freebee somewhere.
The other failure mode on this piano is the electolytic coupling caps on the output board - I've replaced all of them on both pianos - don't remember the value offhand.
Paul Prestopino presto11@verizon.net
Sep 21, 2009 | Music
Manuals for Concert Piano Korg C-15
I have a Korg Concert Piano (C-15S) which was working perfectly till about two months ago. I have been on vacation for two months, had left the piano unplugged from the electric supply point, but on re-connecting now, I get no sound from it. Is there a reset button (or other device) that I may have to use? Appreciate your advice.
Thank you,
L. Paul
Apr 03, 2009 | Yamaha Full-Size Keyboard
Music Logo
48 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
