Question about Lexmark X6170 All-In-One InkJet Printer
Cannot get scan bar to move
I cannot get my printer to scan anything. it says it is doing it, but the scan bar does not move. it copies just fine.
  • 210 Answers
It sounds like the scan driver is malfunctioning. Reconnect both ends of your printer cable. If that does not work, uninstall all of the Lexmark software from your computer and reinstall.
If you are an advanced user, you could first try just removing the Lexmark printer from the Windows Device Manager.
Posted on Jul 30, 2009
HP PSC scans with black line
If printing is ok there're two things that could cause that defect when scanning/ copying:
-. If printer model has both ADF and cam glass and problem only occurs when using the ADF then you should check the ADF glass for something obstructing light path (tipex or other type of dirt)
-. If the printer only has cam for scanning then the problem is on the sensor itself (the "bar" that moves when you scan something inside the scanner). It's not usual that dirt enters the sensor as It's pretty hermetic so I would think that the sensor is damaged and will need to be replaced.
Hope this helps.
Jul 08, 2012 | Office Equipment & Supplies
HP Officejet Pro L7680 All-In-One printer. copies come out black
Probably either the scan lamp or the sensor bar has failed. Do you see the scan lamp glowing under the cover when you try to scan a document? (Lift the edge of the cover slightly and watch the underside of the cover, you should see the reflection from a bright bar of light moving from one end of the original to the other. Do not look directly down into the light if it is on!)
Nov 25, 2011 | HP Officejet Pro L7680 All-In-One Printer
Dark, vertical stripe on copy on Sharp AR-M160
Have you cleaned the small, narrow glass window leftmost of the platen? It is directly above the scanning bar's "home" position, and that's where the document is scanned, while it's fed by the feeder, passing over the bar (the paper moves, as oposed to platen scanning, when the bar is moving and document remains still).
Feb 10, 2010 | Sharp AR-M160 Laser Printer
Scanner & Copier doesn't work
If you get this error when trying to scan from the computer try starting the scan directly from the device and see if that works. If not, unplug and replug the USB cable(assuing you are connected to the computer via USB cable) and install the driver, if you get any plug and play prompts. Let me know if this doesn't work.
May 06, 2009 | Lexmark X5470 All-In-One InkJet Printer
Scanner bar will not move to scan the paper to be copied.
a piece of plastic locks your scanner in place, it is under the scanner up above where the copies come out. It turns 90 degrees.
Maybe some one turned and locked it.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
COPY FUNCTION IN OP
There is a knob on the left side underneath, above the output tray, that locks/unlocks the scanning mechanism. Sometimes it slips into the lock position by itself. Make sure this knob is turned to the unlock position. You might want to cycle the power to reset everything.
Feb 24, 2009 | Sharp AL-1655CS Laser Printer
Lexmark x7350 will not scan, fax or copy
If under warranty contact mfg for warranty repair locations
Sep 09, 2017 | Lexmark X6170 All-In-One InkJet Printer
Can't manually make copies or manually fax.
hi i need 4110 scan 7copy &printer
sofeware driver pl arrange me
Mar 05, 2008 | HP Officejet 4110 All-In-One InkJet...
Scan bar not moving
SHALOM H, HOLA, NO CONSIGO QUE FONCIONE EL SCAN? GRACIAS
Dec 26, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
