Question about Zenith Televison & Video
Small picture size on Zenith 50 inch plasma
I have a 50 inch plasma that I replaced the controller board on (the CATV input was broken). I replaced the board with a new one, but now the picture is only about 20 inches diagonal in the middle of the screen. I'm assuming I can connect serially to the board to make the needed change to the picture size, but was hoping some one could tell me the proper procedure. Any help is greatly appreciated!
  • Zenith Master
  • 9,639 Answers
You should be able to zoom, and stretch the picture with the remote control. Since you replaced the main board you lost the settings that were in memory. Simply re do them once more.
Posted on Jan 06, 2014
SOURCE: Panasonic TV 50 inch plasma
I had the same problem and found that I was viewing the TV input instead of the composite input. Once I changed it back, the aspect setting would hold.
Posted on Feb 10, 2008
SOURCE: we have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
Posted on Oct 24, 2008
Axle80
  • 73 Answers
SOURCE: 50" Plasma Vizio P50HDTV10A - no video - just flashing B & W
Don't replace anything, Vizio has issued a lifetime warranty for this set because of this problem. No joke, call the customer service line and tell them you got the pop of death. They'll send someone out to 'repair' the set free of charge. If they can't fix it they'll give you a new one. Even if your mfg purchase warranty has expired. Call them and post the results. I've been fixing TV's longer than I care to admit and this is the first time I've actually seen a company stand behind their products like this. I bought a broken tv with the intent of fixing it and after replacing almost every board I could only manage to get the vertical racing stripe line, except mine was purple. I put it all back together and called to find out if there was a recall on this set and within 5 minutes the (Actual English speaking) gentleman told me to sit tight and he'd have a repairman come and do his thing. He did, and long story short, he couldn't fix it. Last week they delivered a new TV to replace this one. I was shocked. I think Vizio will have all my future business.
Good luck.
Posted on Mar 23, 2009
SOURCE: Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Posted on Sep 21, 2009
jan mczeal
  • 632 Answers
SOURCE: my 50 inch zenith plasma tv model number Z50P3
The problem lies in the X-Drive boards or the TCPs (tape carrier packages) and they are not serviceable. Once faulty the X-Drive boards must be replaced. The worst scenario is a bad TCP because it indicates a bad panel and you have to replace the panel.The X-Drive boards deliver color information to the vertical grids of the panel through the TCPs. That's why when a fault occurs in the TCPs, vertical black bars appear on the screen and an a much larger part when an X-Board fails. Your TV uses three of these boards, one each driving the right, center and left portion of the plasma panel. The left X-Board has eight TCPs and seven to each of the right and center X-Boards. In your case, the vertical grids driven by the center X-Board is dead but you can't tell the board has failed, It is due to the fact that both the right and left boards are okay but only two TCPs are good on each of them. Meaning there are six bad TCPs on the left board and five on the right. Remember a bad TCP indicates a bad panel and you have at least eleven bad TCPs. The only solution here is buy a new panel or probably a salvaged one auctioned on ebay or have your set or its parts auctioned on ebay then buy a new plasma TV.
Posted on Dec 04, 2009
My zenith 50in. tv keeps saying check external input link status.what does that mean?
The main board needs replacement. you should be able to get the replacement main board from www.tvcircuitboards.com
Dec 11, 2012 | Zenith P50W28B 50 in. Plasma Television
My 50 inch zenith plasma tv popped and now i only get sound no picture
these can be a bit costly. I would call around and get a few prices. It maybe cheaper to buy a new set.
good luck
Jun 01, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
Please help us solve the red line through our 50" Zenith plasma
write an experience that you went trough where you had to use to help you solve this.
Apr 21, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith plasma tv no pictures only sound
my 52 inch zenith plasma has no picture,but has a perfect sound.what could be the problem?
May 06, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
ZENITH PLASMA
there is 4 boards that need replaceing
Mar 09, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
NO PICTURE, YES SOUND
Just had my Y board replaced today. Cost about 500 for board and labor.
HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
Dec 04, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
We have samsung 50 inch plasma tv, we have only half a screen
Nov 19, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Dear RyanVa21;
Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote.
Please let me know if that did it.
Thanks!
Richard
Nov 08, 2007 | Panasonic TH-50PX75U Plasma HDTV
Panasonic 50 inch plasma tv
It's hard to say without seeing a picture. Panasonic has a site with pictures of various Plasma symptoms and the board that will cause that problem. Go to: http://www.pasctraining.panasonic.com/PASS/elearn/PDP.htm Click on: Pictures of plasma symptoms It will direct you to a PDF file. It may not be your exact problem, but, it will show you which board will cause your problem. Hope this helps.
Apr 21, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
Televison & Video Logo
37 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
