Question about ION Block Rocker
ION Block Rocker sound
Ion block rocker has no sound
The tweeter stopped working on my Ion Block Rocker, any suggestions? Tore apart, all wires are still connected.
Take the tweeter out, and tap wires to a AA battery to the connectors. If no clicking sound from tweeter, it's fried, and you need to replace it.
Jun 13, 2016 | ION Block Rocker
I have an ion ipa56c block Rocker. The battery is brand new. It gets a full charge and only last a few hours . Help
Block Rocker™ Bluetooth iPA56C - ION Audio
www.ionaudio.com/products/details/block-rocker-bluetooth-ipa56c
Block Rocker Bluetooth iPA56C provides up to 75 hours of on-the-go sound with its long-lasting ... A high-quality microphone is included to get you started.
RE: Block Rocker Bluetooth model differences - Ion Audio ...
community.ionaudio.com/ion.../block_rocker_bluetooth_model_differe...
Jul 6, 2014 - IPA23 - Explorer Bluetooth, Block Rocker Bluetooth, Block Rocker ...Besides the addition of another bluetooth port and the 75 hour battery on ... Bluetooth models IPA56B or IPA56C..... and between the last 2 what the differences are ? ... I have a model that says it's a iPA56B but only has a 50 hr. battery life.
Amazon.com: Ion Audio iPA56D Block Rocker Portable ...
www.amazon.com > ... > Karaoke Equipment > Players
Amazon.com, Inc.Amazon.com: Ion Audio iPA56D Block Rocker Portable Bluetooth Speaker System ... I work at gm and have bought 4 bluetooth speakers before this one for work use, ....block rocker battery power lasts only a few hours and blue tooth stopped ...
Amazon.com: ION Block Rocker Bluetooth Portable Speaker ...
Amazon.com, Inc.Ion Audio iPA76A Block Rocker Portable Bluetooth Speaker System with ..... I work at gm and have bought 4 bluetooth speakers before this one for work use, All of .... block rocker battery power lasts only a few hours and blue tooth stopped ...
ION Audio Block Rocker, Job Rocker, and Tailgater - Battery ...
noterepeat.com > ION > Portable Audio
Feb 08, 2016 | Tablets & eReaders
Where is the fuse
It is under or next to the socket where the cord plugs in for power. You actually have to pull the cord out to get to the fuse. On the smaller black bluetooth rocker it has one inline with the battery.
Apr 08, 2014 | ION Block Rocker
Battery does not charge
if the unit is more than 3yrs old the batteries could be dead.
Jan 31, 2014 | ION Block Rocker
When audio is turned up sound becomes distorted and intermittent. what can be causing this problem?
You are undoubtedly overloading the whole system - are you sure the power supply is 'big' enough to cope with excess audio power?
Jan 09, 2014 | ION Block Rocker
Schematic diagram power supply
IT SOUNDS LIKE YOU MAY HAVE BLOWN YOU CAPACITORS AND OR OTHER COMPONENTS, FIRST CHECK THE FUSE. IF YOU HAVE A MULITI METER IT SHOULD READ AROUND 0 OHMS
Nov 23, 2013 | ION Audio Ipa16 Block Rocker AM/FM...
Ion Block Rocker
The fuse is house in power cord hook up prob like 1.5 amp gma type
May 27, 2013 | Audio Players & Recorders
Ion block rocker won't hold a charge
Yes you can! I just did today. You need a philips screw driver.
If you have the white ion Block Rocker, find the access panel to the battery on the side of the device, (Facing the speaker it's the side to the left).
I suggest using a kitchen counter, island, tool bench for doing this job.
1. There is a simple 4 screw access door. Find it (opposite the side that has the charge lights and power switch).
2. Remove the screws, put in cup or saucer.
3. The door itself is super tight fitting, and you will need to turn the box on its side, battery door facing down, and gently bounce/tap/knock the device to work the door out were you can grab it with finger nails and work it open. (Gentle and patient but purposeful drops from an inch or so, no more, checking each time to see if the door opens. You don't want to damage the equipment. Pull out door and set aside.
4. Battery is also super tight in the access and suggest the same method until you can get some fingers on on the battery and work it out. I had to uncouple the horseshoe connectors + and 1 from the battery before i could pull the battery completely out.
5. Go to Battery PLUS, or Radio Shack with the battery in hand, to ensure you get the right one. SIZE MATTERS IT MUST BE EXACT. get a new one and RECYCLE THE OLD BATTERY with the store.
Follow reverse order to install.
Good Luck and let me know if it works. Dave S. Show Less
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/bentley_420a7d90885c2203
Dec 16, 2012 | ION Block Rocker
ION Block Rocker Logo
41 people viewed this question
Top ION Audio Players & Recorders Experts
Bentley Self
Level 1 Expert
Mark Mc
Jay Plesset
Are you an ION Audio Player and Recorder Expert? Answer questions, earn points and help others
