Question about Vacuums
Dyson troubleshooting no power dc07i
  • Vacuums Master
  • 18,424 Answers
4 Suggested Answers
  • 134 Answers
SOURCE: dyson dc07i - power okay but roller not turning and picking up
If the roller is not turning you need to replace the belt. They normally supply a spare when you buy it
Posted on Feb 20, 2009
Samyfam
  • 379 Answers
SOURCE: I have a Dyson DC07i
Most likely the ratchet mechanism on the switch is faulty.
Switches are available if you search oneBayfor a few pounds, and if you've reasonable DIY skills and tools, it's fairly easy to do.
Have a look athttp://www.dysonmedic.com/DC07%20Folder/DC07%20Motor%20change.htmlwhich has some great info on your machine.
Posted on Aug 17, 2010
Samyfam
  • 379 Answers
SOURCE: how do i change the fan belt on a dyson dc07i
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look atwww.dysonmedic.com which has some excellent info on dismantling and repairing a DC 07.
Posted on Sep 28, 2010
My dc07i has power to hose but isn't picking up when hovering carpets or hard floors the roller is going round but there is no suction
I would guess that the line is plugged between the pick-up where it goes to the dirt tank. Lots of time when something big gets sucked in, it still lets the dirt in the tank. However over time dirt collects around the wedged object and gradually over time plugs the passage way. It may take a little time to pick out the blockage. You may have to somewhat take it apart. to get at it. This happens to my shop vac a lot.
Dec 31, 2014 | Dyson DC07i Bagless Upright Vacuum
Why does my start stop button not stay on
the switch is fault or dirt has got into it. replacement or you may be able to blow it clean with compressed air but you first must remove the cover. you need a torx screwdriver
Aug 25, 2014 | Dyson DC07i Bagless Upright Vacuum
The holes on my dyson dc07i are dirty and smell how can i get them clean does the part with root cyclone on it come apart
Hi Susan,
We'd strongly advise against attempting to disassemble the cyclone pack, as this is likely to snap the internal bin-base release rod, and can also reduce the performance of your machine.
If you're concerned about the smell from your machine, I'd encourage you to get in touch with us directly, by calling 0800 298 0298 (UK), or 1-866-693-9766 (US). One of our advisors will be happy to run through some troubleshooting checks to make sure the smell is coming from the cyclone pack. They'll also be able to offer advice on the best way to resolve this issue without damaging your machine.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 29, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do you get the tools to work on a dyson DC07i. I am sure it is easy, but I have been given the vacuum and have no manual. thanks
The tools simply fit on the end of the wand or if you wish you can take the wand off, slide the hose down completley to the bottom of the wand, press the wee button atthe end of the hose and this will take the wand off the hose. The tools can then fit onto the hose part
Feb 21, 2011 | Dyson DC07i Bagless Upright Vacuum
I can smell a burning rubber type smell coming from my dc07 i. i've switched it off but what can the problem be and can I fix it myself?
More than likely it's coming from the belt in the power head. Due to some difficulty in taking the power head apart and reassembling, I do recommend taking it in to a shop. Getting the tension of the belt correctly is very important. Too tight and it will break the belt, or even cause the motor to burn out sooner than expected by making it work harder. Too loose and you'll have the problem you're having now, and will have to replace the belt again.
Also, hair and thread or dirty bearings on the ends of the roller brush will result in the belt burning out/breaking faster.
Jan 18, 2011 | Dyson DC07i Bagless Upright Vacuum
I have a Dyson DC07i which I can only switch on and off at the mains, not on the vacuum. Could you please advise
Aug 17, 2010 | Dyson DC07i Bagless Upright Vacuum
MY DYSON WILL NOT GO BACK IN THE UPRIGHT POSITION
Hi there I have seen this problem quite a bit so I have made a video of it. Click here for solution to my dyson dc07 won't stand up. If it helps you out please take the time to leave a comment or give it a thumbs up. If you need filters or spares for your Dyson you can buy them online at VacuumSpot NelsonVacuums.
Happy Vacuuming :)
Jun 30, 2010 | Dyson DC07i Bagless Upright Vacuum
Dyson dc07i - power okay but roller not turning and picking up
Feb 20, 2009 | Dyson DC07i Bagless Upright Vacuum
Vacuums Logo
42 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
