Question about AVF Affinity Blenheim 32" Single Cabinet Door 800 TV Stand Color: Walnut
Affinity TV and need the remote control code for comcast dta control
Program remote for comcast
Check these codes: 11144, 11240, 11331
programmmming TVTV control
The Comcast DTA remote control is preprogrammed at the factory to operate the DTA receiver. The Comcast DTA remote also contains a universal TV library to allow you to control the Power and Volume of your TV.
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold Setup until the Red Light blinks twice, then release Setup.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
Jul 16, 2012 | Olevia 227-S11 27 in. LCD TV
Need a remote code for comcast dta to work with my GPX TDE1380 tv dvd combo
There is no setup codes for GPX with Comcast DTA remote control.
Apr 23, 2012 | GPX TV6000 9 in. TV/DVD Combo
I need a coby tv code for comcast DTA
Code 11265 worked for my 19" model 1926 TV
Feb 21, 2011 | Televison & Video
Comcast DTA code for my HTR-D11 Haier Remote
<a heref="http://universalremotecodes.blogspot.com/">Magnavox Universal Remote</a> CHECK remote codes here!
Jul 10, 2010 | Televison & Video
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Apr 25, 2010 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Need to program remote, don't have codes
RCA TV/VCR Combo Model T09085:
Comcast Digital Adapter Remote (DTA) Code is... 00000
Comcast Universal Remote - Red OK/Select Button (DTC)
Code is... 21479. This code controls TV On/Off and VCR All functions. I could'n find code for vol+/vol- and mute.
Oct 23, 2009 | Televison & Video
Need TV codes for using the comcast DTA remote
I just went through this last night with combo, similar model. They tell you to use the power off test to see when you've got it - nothing worked for that. Then I tried the Panasonic codes and used the volume control as a test, which is much more important, and I found the 3rd code worked for that. I figured, close enough for me, and better than nothing.
Sep 09, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
The manual does not list the actual remote control code
 It will be one of these:
11866, 10054, 10030, 10706, 11990, 11963, 11913, 11904, 11525, 11365, 11198, 10802, 10230, 10187, 10186, 10179
As found in the online manual at::
http://www.comcast.com/DIGITALNOW/Contents/DTARemoteGuide.pdf
I hope this helps
Sep 08, 2009 | Philips Televison & Video
try these codes for broksonic 10236,10463,11911,11938, 10030,11935,11929
Apr 25, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
AVF Affinity Blenheim 32" Single Cabinet Door 800 TV Stand Color: Walnut Logo
Top AVF Affinity Televison & Video Experts
Electro Med Services...
Are you an AVF Affinity Televison and Video Expert? Answer questions, earn points and help others
