Question about Panasonic KX-T7630 Corded Phone
Music through phone speaker
I cannot find a way to turn off the radio that we have tuned into the phone. It's coming through the phone units speaker. How do I turn this off????
    Problem Solver:
  • 9 Answers
If you have a Panasonic KX-TAW PBX, check here for your model: This appears to cover most of the newer model Panasonic PBX Systems.
Posted on Dec 10, 2007
I have a Schwinn Blue Tunes Bike Speaker. It pairs to my Samsung galaxy S4 through Bluetooth with no problem. I am able to control my spotify account with no problem using the device. I am able to play,...
It seems many people use only the term "paired" when talking about CONNECTING two Bluetooth devices. Connecting two Bluetooth devices means first "pairing" them and then "connecting" them. Pairing is a one time process done only the first time you try to connect the devices. It is like the two devices getting to know about each other. Next step is to actually connect the two and this process is done the first time after the pairing and then every time you want to use the speaker from your phone. When you open the Bluetooth tab on your phone's Settings menu you will see the names of all the Bluetooth devices it has been paired with previously and a "Paired" word next to it. If you want to use the device/speaker, tap on the name and it will CONNECT to it. You will see the word "Connected" instead of "Paired". Now you should have the music that you play on the phone coming out through the speaker. If you still can't hear the music over the speaker after a successful connection, turn up the volume on your phone (and on your speaker, if it has its own volume controls).
Feb 08, 2015 | Samsung Radio Communications
I turned the aux function on on my alpine cdm 9821 unit. I purchased an audio adapter with a red and white plug (to plug in the back of the reciever) on one side and a regular 3.5mm headphone jack on the...
You must make sure where you plug in on the radio side is Aux input, most Radio Aux is at the front or come with special connector if it is at the back. Mostly radio back come with RCA is for Line out not Aux in.
Nov 28, 2013 | Car Audio & Video
I have a 2002 electra glide classic and the clutch side speaker stopped working. I purchased some hog tunes with an amp and it still does not work, but can hear music come out very softly when i disconnect...
The radio's internal amp is blown. You are still using the internal amp to supply the output to the Hog Tunes amp, so just installing an aftermarket amp will not solve the problem. The radio will need to be repaired.
Try these guys.
Dec 31, 2010 | Harley Davidson 426290 AM/FM Radio
Problem with Airport express to BOSE Lifestyle
When i play the radio on my bose lifestyle , my radio sounds good. but when i send music with from my apple computer to . airport, and then to my bose lifestyle, the sound just come out from on 1 speaker. not the toher ones, but when i play radio all 5 works....
anybody got a solution??
Alex, Sthlm
Jan 20, 2010 | Apple AirPort Express with Air Tunes
Regarding a Yamaha RX-V757 receiver, if I have my volume set above approximately -28, whether I'm playing a DVD or listening to a music CD, the units power shutsoff. When I turn it back on the display says...
Try turning up the volume with just the FM selected (and tuned to a station). If you can adjust the volume to an appreciably higher level when simply tuning in a radio station, then your CD/DVD player may be outputting a signal with a DC offset, which is getting amplified when you turn up the volume, and past a certain point the protection circuitry is sensing too much DC being sent to the speakers and shuts the unit down. If the unit is getting hot, there is likely an internal problem, or you have a shorted speaker wire, or even a bad speaker. Replace the speaker wires as a test, and you can also run the unit with only one speaker connected at a time to see if any are the source of your problem.
Yes, it's possible that there's nothing wrong with the wires or the speakers, and the unit simply needs a trip to the shop, but it's your job to rule out the easy stuff before you pack it up and take it in.
Nov 21, 2009 | Yamaha Audio Players & Recorders
Red light isn't indicating it detects source
I have the same model as you.
Plug in the transmitting unit into a good working power outlet. Make sure you have the audio connected to a loud source. Turn on the source device producing the loud audio to be transmitted to your headphones. (This being your IPod - Turn it full blast). Now see if the transmitting unit's LED light is on. Check headphones for audio. (May have to tune in the headphones till green and adjust its volume as well).
Note: Some radio stations bleed over into the headphones and you may have gotten the "Beautiful Music" from this radio station frequency harmonic anomaly. Keep tuning your headphones till you hear your music or audio source.
I recommend that the source of your audio have its built-in speakers off, while still providing audio out to your transmitting unit, via an external audio output. Check your source manual or look for audio jacks on the front or back. There may be a setting to turn this on and for the main built-in speakers to be turned off as well.
If this does not work, unplug the transmitting unit, and then plug it back in again, after waiting for about 10 seconds - all while audio is being provided to the unit. It should come on.
Jul 26, 2009 | RCA WHP140 Consumer Headphones
Hyundai sona98A radio and audio do not work
Radio has static on the AM station, also radio does not have good sound coming from speakers. I have tried to tune the radio but it still sounds very monotune The music coming from Radio sound bad.
Dec 08, 2008 | Car Audio & Video
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
How do you play the radio through the NEC Dterm80 Phone System
The NEC phone system needs to have a radio attached to distribute the music to the phone sets.
It is not illegal to play the radio through a phone system (radio advertizements pay for it)
This is a Dterm 80 phone set
To turn Background Music on or off:
1. Press the Speaker key.
2. Dial 725.
3. Press Speaker to hang up.
Feb 27, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
413 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
