Question about Kenmore Washing Machines
Spin cycle stuck makes loud noise
My Kenmore 70 fills, agitates, drains but does not spin the basket, the coupling is still intact and spins the drive just above the coupling, is there something else just for the the basket that could be replaced....this happened after I washed a large comforter.
  • wroseborough May 19, 2009
    My Kenmore 70 fills, agitates, drains but does not spin the basket, the coupling is still intact and spins the drive just above the coupling, is there something else just for the the basket that could be replaced....this happened after I washed a large comforter. If its not the coupling what else could it be and how do I replace that part?
  • 15,935 Answers
Assuming your washer is direct drive 70 series (no model # given)... and the coupling is intact... you may be experiencing an internal gearbox problem.
This is a 9 out of 10 on the difficulty scale - and probably not a good idea to attempt if you have never done this type of repair before.
If you wish - please use the "continue with this expert" option and reply with the exact model # of your washer (ex. 110.875477), and I can point you to a new transmission.
Additional information would be helpful too...
Are you checking the agitate with clothes in the machine - or just water?
Can you spin the agitator by hand?
Have you tried to "help" the spin cycle manually while its trying to spin?
Is there any clicking sound during or just before the "spin" cycle?
If you advance the timer manually - does it spin?
Thanks for using FixYa - please remember to use the "Continue with this expert" so we are connected in the future.
Posted on May 20, 2009
  • blueextc3221
    blueextc3221 May 20, 2009
    one more thing you may want to check is the lid switch - it will not spin if the safety switch is bad.
    with the lid open (when its supposed to be spinning), use a screwdriver to manually trip the switch.
    Do you hear a click when you press it?
  • blueextc3221
    if you feel the switch isnt acting properly - you could add a jumper wire (if you have that skillset) between the poles of the switch and see if the drum begins to spin.
    Novelist:
  • 130 Answers
It sounds like one of two things :
1. By pass the lid switch to rule this out as a problem.
2. I would replace the clutch, and see if that fixes it.Mostly in 99% cases clutch replacing will solve problem
3. If that does not fix it, then you are looking at replacing the brake tube assembly or the motor coupler is gone.
thanks.please do not forget to accept the solution.keep updated.
Posted on May 19, 2009
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Basket won't move-noise
do you notice if it agitates?
if it doesnt agitate it is just a simple coupling
if it is making a humm noise its the motor
if a LOUD rumble ONLY on spin cycle, its the basket drive assembly and the clutch.
May 29, 2009 | Whirlpool LSQ9610L Top Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series agitates but does not drain or spin cycle.
If the unit is not draining or spinning it sounds like a lid switch. If the unit is draining but not spining it sounds like a drive coupling.
Dec 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine 70 series
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
56 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
