The tube seal is leaking and this means the tub bearing may be worn out, this is a huge job to replace and requires lots of hand tools and a good amount of mechanical skill.. If you are up to the job contact a website called the repairclinic for tech help and parts if you prefer.
On the GE Adora machines, if the unit is not getting the correct power, the unit will not go beyond the fill point to wash. You will need to replace the "power inverter" on the unit. Here is the part you need to order.
changing from large to small load will not cause a problem. this could be a control panel issue. unplug machine, the try rotating load size dial back and forth a few times, plug machine back in and try
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
