Question about Home
My gas log will light on pilot but will not light fully.
I have cleaned the orfus tube and replaced the batteries in my remote.
  • 38 Answers
Typically, if the pilot stays on and the logs won't light, the thermopile or entire pilot assembly could be bad. If you have an IPI system [automatic lighting system from remote or wall switch] there may be an issue with the control module.
Posted on Sep 20, 2014
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Nov 26, 2013 | Woodland Direct CD Vent Free Gas Log Set...
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
Pilot flame curves upward missing thermcoupler copreci style 1 in gas logs by Desa Int, can I fix?
pilot is blocked needs cleaning orfice is blocked try blowing pilot with can of air , when off , or tube and just blow .
Jan 06, 2011 | Desa International CCL3924PTA 24" LP Gas...
Hi. i have a vermont castings radiance stove, RDV40. the pilot light went out and won't reignite. yes, the gas is on. i've followed the manual -- turning the control knob to pilot and pressing the ignition...
check to make sure your pilot orfice is not clogged it will be located at the end of the small tube coming from your gas control valve if its not then while you are trying to light the pilot tap the side of the gas valve (sometims somewhat hard) if it then lights you know you have a bad gas valve
Aug 25, 2010 | Heating & Cooling
Pilot lite went out and will not relite
The thermocouple is not functioning. The t/c is the small (sensor) tube that the flame touches and should have a small copper tube (capillary) extending to the gas valve. (IMPORTANT: The capillary tube should not have any kinks or crimped places...Only gentle bends. A crimped tube will require t/c replacement.) The flame will deposit a coating (minerals) that will insulate the t/c and prevent it from working. Clean the sensor with steel wool, fine sand paper (emery board) or scotch pad. Now try to relight the pilot making sure the t/c sensor is contacted by the flame, if not, shut off gas and adjust. Once aligned and contacted by pilot flame, hold for a minute, allowing the t/c to warm up fully and signal the gas valve to operate when knob is turned from pilot to operate.
Jul 16, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
I can light pilot but cant get main burner to stay on. Ive cleaned out hooded pilot with wire. what next
Clean the gas tube before the pilot light with a small wire. If you don't light these units every month or so you can get all sorts of bugs and critters that will call your gas tube home. Second option - Either the thermocouple is bad or the gas control valve is not opening completely. Try replacing the thermocouple
Mar 05, 2010 | Endless Summer (GA200209) Stainless Steel...
My pilot light kept going out. I cleaned it
You may have to get a new thermocouple.
This is a small copper tube that goes from the pilot light area to tha gas valve.
It feels the heat from the pilot and keeps the gas valve open for gas to flow to the pilot or to the logs when in the lit position.
Without the gas valve will stay closed.
Jan 06, 2010 | Vanguard International Blue Flame - Medium...
After about 5 years with no problems, the emberglow vent free gas logs are not igniting. the gas is coming out as i can hear it, but the ignite switch doesn't have any effect. if i hold a lit lighter in...
Sounds like a bad pilot sensor called a Thermocouple. It is a copper tube that goes from the gas valve to the pilot assembly. It is the smaller of the two tubes. They are available at better hardware or farm stores. It is best to unscrew it from the gas valve and pilot assembly and bring it with you when you shop for one. It is something any mechanically inclined homeowner can replace.
Dec 03, 2009 | Desa International CCL3924PTA 24" LP Gas...
No gas flow..will not light..have replaced gas tank valve and have cleaned everything, replaced ignitor battery, all connections both electrical and mechanical look good.
Check the pilot tubing for spider webs. take a piece of 16ga. stranded wire, strip abou 1/2" of insul.and spider leg the wire and run through pilot tube.
Oct 26, 2009 | Heating & Cooling
Home Logo
140 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
