Question about 2004 Mustang Factory Wiring Diagrams
1996 holden astra instrument cluster removal
How do I remove the instrument cluster
    Prodigy:
    An expert who has answered 500 questions.
  • 545 Answers
Hiya. IK found this to bea simple task on my UK Vauxhall Astra, it starts with two screws on the upper side of the speedometer binnacle.
Posted on Jun 30, 2014
How to replace the headlight switch assembly on a 1997 dodge grand caravan
The best I can offer is for a 1996 caravan:
REMOVAL
  1. Remove steering column cover.
  2. Remove over steering column bezel.
  3. Remove left end cover.
  4. Remove screw at left end of cluster bezel and headlamp switch.
  5. Remove screws holding cluster bezel to instrument panel from each side of steering column.
  6. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
  7. Separate cluster bezel from instrument panel.
Disconnect wire connectors from back of the bezel.
INSTALLATION
  1. Connect wire connectors into back of the bezel.
  2. Place cluster bezel in position on instrument panel. Use care not to place hands on louvers.
  3. Connect clips to hold cluster bezel to instrument panel. Use care not to add pressure on the A/C louvers to seat the cluster bezel clips.
  4. Install screws to hold cluster bezel to instrument panel on each side of steering column.
  5. Install screw at left end of cluster bezel and headlamp switch.
  6. Install left end cover.
  7. Install over steering column bezel.
  8. Install lower steering column cover.
May 02, 2015 | 1997 Dodge Grand Caravan
How to remove dash
the plastic shroud around the cluster just pulls out as its a snap in piece. then there are screws that hold the cluster to the dash frame that need to be removed. you can pull the cluster forward enough to disconnect the electrical plugs on the back of the cluster then you can remove it.
Sep 19, 2014 | 1996 Plymouth Voyager
Astra aircon switch
1.remove the audio system.
2.remove cig lighter
3.remove lower compartment door and assembly under radio.
4.remove compartment under radio
5.then remove all necessary screws that hold the plastic panel on.
6.once all screws are removed and you can either lift the panel up enough or remove it total depending on you.then you will have easy access to the switchers..
Jan 04, 2014 | Holden Astra Cars & Trucks
How to replace rear brake pads on a 2001 1.8 holden astra
You will need a wind back tool to do the job properly, but it's not hard to do, remove the wheel and then remove 1 of the 12mm bolts on the caliper it should lift up exposing the pads, remove the old pads and using the windback tool wind the Pistons back enuf to fit the new pads, hope this helps
Jul 29, 2012 | 2004 Holden Astra Cabriolet
1996 grand am instrument panel cluster is not working
Open driver side door, remove fuse access panel on the left side of the instrument panel and check the instrument cluster 10A fuse behind on the fuse block (third row from the top, fourth fuse position note: first two position may be empty). If fuse checks out the connector behind the instrument cluster may have worked loose. Remove steering column covers, remove bezel around the instrument panel (this is held on with push clips), remove four screws from the cluster and ease the cluster out just enough to see and correct the problem. hope this has helped.
Oct 16, 2011 | 1996 Pontiac Grand Am
Can you replace the lights behind the instrument panel? the entire right side of my dash is no longer lit up
Sure Can
Buy bulb number 161
Instrument Cluster Finish Panel
Removal and Installation
1. Remove three screws along the bottom of instrument panel steering column cover (04459). Pull on instrument panel steering column cover to unsnap the three clips across the top of the instrument panel steering column cover. Remove the lower instrument panel steering column cover.
2. Remove four screws retaining the steering column shrouds (3530) together and remove the steering column shrouds.
3. Remove the three screws retaining the bottom of the cluster instrument panel finish panel (044D70).
4. Remove two screws retaining the cluster instrument panel finish panel above the instrument cluster face.
5. Pull cluster instrument panel finish panel to unsnap one retaining clip above the LH A/C register (19893).
6. Pull cluster instrument panel finish panel to unsnap three retaining clips on the RH side vertical edge.
7. Pull cluster instrument panel finish panel away from instrument panel (04320) far enough to disconnect the wiring connector(s).
8. To install, reverse Removal procedure.
I've never done #2, and #1 refers to the panel below the steering column. To remove it completely, pull it towards the driver's seat. There may be retaining clasps on it also.
May 25, 2011 | 1996 Ford Thunderbird LX
Looking for a holden astra LD 1989 workshop manual
  • Nissan Pulsar N13 and Holden Astra LD 1987 - 1991 Workshop Manual Repair Manual for Nissan Pulsar N13 Series & Holden Astra LD Series ... N13 and Holden Astra LD 1987 - 1991 Workshop Manual ... 1987, 1988, 1989, 1990 and 1991. Holden Astra LD ...www.automotobookshop.com.au/gregorys-?nissan-pulsar... - Cached
  • Dec 07, 2010 | Nissan Pulsar Cars & Trucks
    2004 Mustang Factory Wiring Diagrams Logo
    111 people viewed this question
    Top Ford Vehicle Parts & Accessories Experts
    xxxxxx xxx
    Thomas Perkins
    Thomas Perkins
    Colin Stickland
    Colin Stickland
    Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
