Question about Samsung RS2630SH Side by Side Refrigerator
We have just bought a Samsung American fridge freezer around 1 week ago, we have only just stocked it with new food, we now have a smell coming from it when you open the fride door.
Smells like gone off, sour milk, we have checked all the food in the fridge and it is all still in date and doesn't smell. We did have the fridge slightly tilted back for the first week which we have now sorted, maybe this affected it. Smell seems to come from inside but we can't pin point it, it's very clean inside obviously because it's brand new!! Confused.
    Sergeant:
  • Samsung Expert
  • 302 Answers
Sounds a bit funny if it is a new fridge!! Try washing it out with warm water and a big splash of vanilla essence, works wonders!
Posted on Dec 29, 2013
  • 74 Answers
SOURCE: Bad smell from vent at back of fridge but able to remove back panel
if you cant remove it then wash it unplug the refrigerator from ac outllet first then remove the carton cover in the back and you gona see the pan were the water is temporaly storege with a garden hose washing the pan and then clean the floor use or news paper around the refrigy is helpfull the water or so in the pan is evaporated with the hot of the compresor sistem that water come frome the freeser compartment....good luck and rate me
Posted on Jan 11, 2008
dcp2
  • 63 Answers
SOURCE: Samsung Refrigerator SR-608EV with water dispenser
There is another sensor in the door that senses how far open the door is. look for this and see if its disconnected or broke
Posted on Jan 28, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 1462 Answers
SOURCE: removing doors from a samsung rsg 5 dumh american fridge freezer
doors are removable. wiring to the door is plug and socket
Posted on Oct 15, 2008
SOURCE: SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
Posted on Dec 10, 2008
Very bad smell coming from my Samsung refrigerator
most refrigerators have a small drainage hole leading from the inside rear of the compartment to an overflow container behind the unit, pull the unit away from the wall and check if the liquid in the container has become stagnant, if so simply clean it out and run a small amount of bleach down the hole to disinfect the tube.
hope this helps.
Nov 11, 2013 | Samsung RS261MDWP - 26 cu. ft. Side by...
Last week our electricity was down for some time. Then Ice from freezer fall down from and fridge stop cooling
Hi
These units rely on air being transferred from the freezer to the fridge, so to make sure that the air ways are clear follow the steps below.
1. Empty the fridge and freezer and store the food elsewhere.
2. Switch off and unplug the unit and leave for 24 to 36 hours with the doors held slightly open. You may get quite a lot of water on the floor, you just need to mop it up, this is normal.
3. Wipe out the inside of both sides to leave them clean and dry.
4. Plug in and switch on, wait around 4 hours.
5. Re stock the unit it should be OK.
If there is still a problem please come back to me
Regards
Gordon
May 05, 2011 | Refrigerators
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
Refridgerator and Freezer Not Cooling (2 year old fridge)
Some of these had problems with the door light switches between the doors. They also control the fans. The top and bottom both have fans in back. Try opening top door and holding door light switch in. Wait for a couple minutes to see if fan comes on. Try with freezer too. If not coming on may need switch.
Jun 02, 2010 | Samsung RB215LASH
Freezer not blowing air - bad smell in fridge
Your automatic defroster coil is open and needs to be replaced along with the fan in the freezer that blows the cold air around and also blows air into refrigerator.
Bad smell down below is food rotting in that section because it is not cold enough.
Mar 22, 2017 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Malfunctioning American Fridge Freezer
Is it freezing. Sometimes those led's go out.
Dec 21, 2007 | Freezers
Samsung RS2630SH Side by Side Refrigerator Logo
155 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
