Question about Galfer Yamaha Front Brake Lines XJ 750 Maxim 1983-
1983 yamaha 750 yics leaking gas from carb - Galfer Yamaha Front Brake Lines XJ 750 Maxim 1983-
YAMAHA 550 YICS MANUAL
Hi, Anonymous the vast majority of service, parts, and owners manuals on the internet are "FREE" to download and all service manuals contain wiring diagrams in the back pages. The rest usually charge a modest fee around $10 sometimes more and there is a handful of obscure, rare, obsolete, and very old models that are no longer or never were available, then there is eBay where you may be able to find what you need at a very high price because of its age and rarity. Most of the "FREE" manuals will cover your exact make, model, and year otherwise one will be provided that comes as close as possible to your bike and will have most of the same info that an exact manual would have. To download your manual please click on the links below. Good luck and have a nice day.
http://www.ebay.com/bhp/yamaha-xj550-manual
Yamaha XT550 Service Manual Ocr Small
Yamaha XJ550 1981 1983 Workshop Service Manual Download Manuals Technical
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Sep 27, 2012 | 1982 Yamaha XZ 550
Why is there gas leaking from the air box? On a 1982 Yamaha seca yics 400 motor
Tap not shutting off properly plus sticking float valve in one or more of the carbs
Apr 26, 2012 | 1982 Yamaha XS 400
1983 FZ 750 high idle
Hi, Stevemagney and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
10. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links blue below. Good luck and have a wonderful day.
FZ750 Super High Idle Problem
carb high idle problem
1985 1988 YAMAHA Genesis FZ750 Service Manual Repair Manuals AND Owners... $10 cheap
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Mar 25, 2011 | 1986 Yamaha FZ 750 FM (Japan)
1994 Yamaha Virago 750 has a carb slide not moving,
Hi, Gorunurz and the usual suspects are:
1. Piston atmosphere vent blocked.
2. Piston binding.
3. Spring binding.
4. Diaphragm cap loose, damaged or leaking.
5. Diaphragm pinched at lip groove.
6. Torn diaphragm.
7. Piston vacuum passage plugged.
8. Enrichner valve open, not sealed or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ViragoTechForum com
V2 Carb slides not moving please help
Yamaha XV535 Owners Workshop Manual
http://mybikemanuals.com/yamaha/yamaha-xv-owners-manuals
May 11, 2010 | Yamaha Motorcycles
1983 Yamaha Seca 750 no spark
Check the battery should be 12V or more , Then check the coils the connections are under the gas tank make sure they are securely connected.
What kind of fuse box do you have? The glass fuses? Or did you replace the fuse box. If it is the glass fuses you need to replace with a new fuse box.
Check the kill switch and the side stand switch.
Check the coils too..
Oct 04, 2009 | 1983 Yamaha XJ 650
1983 Yamaha virago. Lots of problems.
sounds like your filter mate
replace the filter she'll be good as new
Jun 19, 2009 | 1988 Yamaha XV 535 Virago DX
Idle goes up and down
It sounds like the carbs need to be taken apart and cleaned. Bike should start up with just choke .
May 19, 2009 | 1982 Yamaha XZ 550
Gas leak
so you have a hole in your tank somewhere. or leaky fuel **** gasket. firstly you need to find the leak. or is your gas just flowing right thru your carbs and out the overflow? shut off fuel to eliminate carbs. if it stops leaking then its probably gummed up carb floats. use Berrymans B12 fuel additive this will work into the carb and hopefully break down the gum. or strip and clean them by hand with a good spray carb cleaner. or remove air cleaner and spray directly into carb and let sit for a few days.
if it's a gas tank leak then you will have to get it lined, (liquid sealer) so long as the hole is not too big. if it is then drain and dry the tank, get it welded professionally or patch it with a filler or fiberglass and then get it sealed, i used my local radiator repair shop to het mine done.
Mar 31, 2009 | 1983 Yamaha XJ 650
1989 yamaha 750 v twin gas to carbs but not to heads
Hi Jilline,
If the carbs have gas and the gas dont get into the sparkplugs this means the main jet and the pilot jet are clogged.
You will have to clean the carbs!
Cheers.
Knight (YamahaSeca XJ750A 1981)
Feb 28, 2009 | 1988 Yamaha FZ 750 BV (Europe-US)
Galfer Yamaha Front Brake Lines XJ 750 Maxim 1983- Logo
27 people viewed this question
Top Galfer Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Galfer Cycling Expert? Answer questions, earn points and help others
