Question about IBM Computers & Internet
After several years of not being used in a warm lager I now started the machine again and it works fine except a dim creeking sound as if in need of lubing. How is that done?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
What ???
Posted on Dec 29, 2013
When we turn our TV on we get sound, but our picture is distorted for about 15 min then it's clear. Any sug?
Your TV is about 5 years old.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 26, 2015 | LG 46LD550 46 in. LCD TV
LG DLE5977s electric dryer drum not turning when warm
Could be one of the "overheat thermostat switches" has failed, or is failing.
Could also be a big buildup of lint inside the machine (where you cannot see it) causing the switches to trip.
In the back or the bottom of the machine are from 3 to 7 "overheat thermostat switches" that are put there to prevent fire.
When the get hot, if they are bad, they will shut off the dryer until they cool off.
Kinda sounds like one is "trippin' ". If you choose to fix it yourself, you'll need a good electrical test instrument and several tools to take it all apart.
A question to "fixya" might get someone to tell you how step-by-step.
Be blessed.
Mar 27, 2013 | LG DLE5977 Stainless Steel Electric Dryer
My scotsman model 506as 1f, serial no. 06021320015994. Was running fine until i had it sent in to a local shop for routine check up during the normal winter down time for the machine. When i started using...
Have you pulled the cover off so you can see the code it is giving really need to know it. sounds like either low charge or hot gas valve not opening during harvest. I really need the code to be able to help you out.
Jul 07, 2011 | Scotsman Ice Maker CM3 30inW Cubed Ice...
2002 Big Bear 400. Dies after a few seconds upon startup
sounds to me the valves are not properly adjusted,..like their to tight,...i had run into this in a japanese car once,...check it out and let me know,.....cracklin joe
Jan 10, 2010 | 2002 Yamaha SR 400
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Gaggia baby dose d (circa 2007) wont dispense water? pump?
Sounds like it needs descaling - not the normal descaling but inside the pump head!
Oct 25, 2008 | Gaggia Baby Espresso Machine
Speakers Popping loudly occasionally. Died for several days. Now working again but still making sounds.
The problem is a burned transistor inside the subwoofer. It depends of country's transistor manufacturer. It is supposed to be of a low quality. It's not important for the scope. Mine is knocked down for a year. I saved the electronic schematic diagram and the transistor specs, but lost. I confirmed the cause opening the subwoofer and examine the board. The indicated transistor surrounded area is burned indeed. If anyone find the article in web, please, post here.
May 12, 2008 | Creative Labs Inspire 6600 Computer...
No responce except thumping noise
PLEASE TRY TO CHANGE AGAIN THE CONVERGANCE IC'S
Oct 02, 2007 | JVC AV-48WP30 48" Rear Projection...
Computers & Internet Logo
14 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
