Iluv manual iMM157
Why my nabi2 is pear with my iluv speaker but can't hear it ?
Probably because they are PAIRED, but not CONNECTED. Pairing and connecting are two different steps in the process of making two Bluetooth devices to communicate with each other. Read the manual on how to connect the two.
Jan 22, 2015 | ILuv Audio Players & Recorders
My Iluv Alarm with shaker for Iphones won't play any music when I try to connect it
do you have it set to the correct input?is the volume up on the phone and iluv?is the iluv device powered.is the iluv device turned on?is the iluv device compatible with you iOS device?Return the iluv device if all else fails it should work, also try using the aux port, many ios devices in fact will charge with other devices however not all iOS devices will interact with other devices, have more questions? just ask
Mar 29, 2013 | Audio Players & Recorders
No sound from iLuv i9200WHT music center 3.15amp fuse keeps blowing
The problem is more than likely in the audio output chips in the unit, check to make sure the speaker wires are not shorting.
May 16, 2012 | Jwin iLuv i9200 Shelf System
Replace battery i903
0000 work for mine. That should be universal for these headphones.
Dec 05, 2011 | Jwin iLuv i903 Consumer Headphones
I lost the manual, and I can't work out how to set the time or alarms.
Follow the link below to a website that has the manual. It will ask you to submit to some optional services, but I know you can just reject it and the manual will come right up.
http://portablemedia.manualsonline.com/manuals/mfg/iluv/i177.html
Jan 03, 2011 | Buck iLuv i177 - Alarm Clock Radio With...
55 people viewed this question
 Grubhead
Grubhead
