Question about Traxxas Rc Revo Nitro Monster Truck
Traxxas revo 2.5r
After starting my revo will only run for about 20 seconds then dies. Have checked pressure on tank and for any leaks can' t find any . Just doesn't keep getting fuel after initial start? You can rev up and truck will run but only for short time. ( not continuing to get fuel)? What can I check next or what could be the issue?
    New Friend:
The engine shutt down just if load and not bobtail
Posted on Dec 29, 2013
4 Suggested Answers
  • 10 Answers
SOURCE: Traxxas Revo 3.3 shifting problem
you might need to reset the opti drive. turn the power on with the engine still off and hold down the optidrive button for 5 sec. see it that works.
Posted on Jul 07, 2009
  • 88 Answers
SOURCE: I have a traxxas revo 3.3 and it turns over but it
The glow plug could be bad. If the motor turns over and is getting fuel I would replace the glow plug.
Posted on Jan 14, 2010
  • 56 Answers
SOURCE: traxxas revo 3.3 running problems
Maybe running to lean or to rich. When you accelerate put youre hand where the exhaust is and you should get a light spraying of unburnt fuel over hands(lovely!). If you do you may be able to screw in high end needle in a bit and i mean just a bit. If you hear the engine note raise a bit with a slightly higher pitch then you are running to lean and you will want to unscrew the high end needle valve asap.
Also check youre idle screw and make sure thats not closing the carb and stopping any airflow into engine. Let me know how it goes.
Posted on May 30, 2010
Not getting fuel to my carburetor! Brand new hoses no leaks...
Check your fuel tank cap, pressure must be released from there you need to change the o ring on the fuel cap.
Dec 01, 2012 | Traxxas Rc Revo Nitro Monster Truck
My 3.3 isnt running lean plenty of smoke and torque. after a tank of gas my plug dies
try turning the needle all the way in the turn 2and 1/2 turns out start with that
Feb 07, 2011 | Traxxas Rc Revo Nitro Monster Truck
Got a traxxas 2.5 i think? Been around plains for years and can tune them fine but for some reason i cant get the truck tuned. Starts fine cold but when running hard smoke goes away and starts to bog....
Sounds like the high end needle might be too lean. Have you checked the engine temp while running. Traxxas engines usually like to run around 210-240 degrees.
Sep 25, 2010 | Traxxas Rc Revo Nitro Monster Truck
3.3 revo hard to start after started it will not idle and when it dies it does not want to restart. This did not happen until I drve it thru alot of wet grass last year
Hi
2 stroke engines are very simple. If there's fuel (under pressure) and a spark it will run. Check the glow plug by trying to start it with glow plug removed but still connected and touching the engine body. If the little center wire glows bright red, then it's OK. Only do this for a second or so. If the plug is OK then it has to be a fuel problem. Traxxas has a long history of cracked gas tanks. Good luck
Apr 30, 2010 | Traxxas Rc Revo Nitro Monster Truck
My revo is getting fuel light on start remote are on both motor and glow plug engine will just turn over but will not start up
Hi
You've checked the glow plug externally to see the wire get red? If so, as long as you've got fuel and fire then it has to start. My guess here is that you have either a bad glow plug, low batteries, fuel air leak or clogged pressure line. Put a charged battery into the starter. Remove the glow plug and try to start - fuel should spurt up through the glow plug opening. Now connect the glow plug and touch it to the engine. Try to start and you should see the glow plug wire glow red. (do this only for a second. Now disconnect the pressure tap from the muffler and try to start. All else fails, replace the fuel line to the carb and the pressure tap. Your carburetor can leak air through the rubber gasket . Also, Traxxas fuel tanks have a cracking problem. Good luck
Apr 14, 2010 | Traxxas Rc Revo Nitro Monster Truck
Start truck and it runs backwards!!
check your remote, the three switches on the bottom.. they control the servo's. one controls the forward and backward servo. test em out. one is bound to turn the servo around.
Apr 05, 2010 | Traxxas Rc Revo Nitro Monster Truck
Traxxas Rc Revo Nitro Monster Truck Logo
153 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
gbob59
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
