Dc error wa5451anw samsung washef - Washing Machines
How do I correct a "dc" error?
google the brand , model , and error code to find out
Jul 28, 2015 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
There is no power samsung wa5451anw/xaa-0002
hum not good
sounds like something has fused and blown the mains
you need to look too a control board error for this ...
its a job for a tech,... for sure..
Mar 05, 2015 | Samsung WA5451ANW 4.7 Cu. Ft. White...
Samsung washer had ND code, checked for clogs, could not find a filter on my machine, drain pump is in back inside panel, I removed hoses and found nothing, now machine will not start a cycle or drain, no...
to start with for your first problem "NF"if u Insert the drain hose too far into the drain it may cause a syphon effect stopping any water from draining out of the washing machine. and that will cause an "Nd" error.and 6e9df0b6-14e5-4444-9dca-eea3526ce7ee.jpgmake sureto the make sure there is power to the washer and if there isn't there is a good possibility it is the
Bearing Seal and Bearings:
May 26, 2014 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Fault error code 8E
an 8E or 8E2 means - Sensor problem.
Feb 19, 2014 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
8E error code on samsung top load direct drive washer
Samsung has us replace Mems sensor, main harness and user interface board. They do not have away to test the mems sensor in the field.
Dec 09, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
I need to know where to purchase the pulsator. The one in the bottom of my washer broke.
Samsung should have a local dealership near you(look up in the phone book), or your place of purchase can point you in the direction of a local serviceperson who can order from samsung for you (sometimes they only sell to registered technicians)
Nov 11, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
I get an error code PE on Samsung washer WA5451washer
PE error code is a pressure sensor code, and more than likely the sensor will need to be replaced. Try unplugging the unit for about 5 minutes and see if it will clear it out. If not, will need to replace pressure switch and hose (switch looks like a little UFO under the console, pretty easy job.
I have a Samsung top load washer #WA5451ANW. Will only fill with water. Had to turn the power off so machine would stop filling with water.
Possible that the cut off to the Inlet valve has failed which means that the controller unit is a suspect. Also if the inlet valve is staying ON even when the power is cut off , then it is a case of inlet valve failure.
Dec 31, 2012 | Samsung WA5451ANW 4.7 Cu. Ft. White...
How to reset samsung washing machine
http://www.samsung.com/us/support/owners/product/WA5451ANW/XAA
Jul 24, 2012 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
