Question about Motorola AP 6532 Access Point
Reset password mac username - Motorola AP 6532 Access Point
Can't login to gmail
Try logging into gmail.com from a PC or Mac. Reset password (using forgot password) on PC or Mac if you cannot get in. Then, set up with known username and password on smartphone.
Jan 06, 2014 | ZTE Warp
Need to reset password on Mac OS X
If you know your recent password, try this:
http://support.apple.com/kb/HT1274
If you do not know your previous password, try this:
  • Boot from the Mac OS X installer disk by inserting it into the Mac and holding down the "C" key on boot
  • Select your language preferences and then under the "Utilities" menu select "Password Reset" (it may say "Reset Password" instead, depends on the version of Mac OS X)
  • Select the hard disk that the forgotten password is on, then select the username of the forgotten password, you'll then be asked to select a new password
  • Reboot as usual from the hard drive, using your newly reset password as the login!
Thanks,
Charvin
Oct 02, 2012 | demonoid.com
How do i remove system lock pin on macbook pro
Resetting a user's password
Note: These steps are for Mac OS X v10.3 or later. For information about resetting a password in Mac OS X v10.2.8 or earlier, see the Additional Information section below.
  1. Log in with an administrator account. Tip: If you don't know the password of any administrator accounts, see "Resetting the original administrator account password" below.
  2. From the Apple menu choose System Preferences.
  3. From the View menu choose Accounts.
  4. Click the lock button if it appears locked; enter the administrator password.
  5. Select the username whose password you want to change.
  6. Click the Reset Password button (Mac OS X v10.3 and v10.4) or the Change Password button (Mac OS X v10.5 or later).
  7. Enter a new password in both the Password and Verify fields, and add a hint if desired.
  8. Click the Reset Password button (Mac OS X v10.3 and v10.4) or the Change Password button (Mac OS X v10.5 or later).
  9. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
Mar 17, 2012 | Apple Computers & Internet
I forgot my password for my imac, and i dont have the disk?
Reset 10.5 Leopard & 10.6 Snow Leopard password
  1. Power on or restart your Mac.
  2. At the chime (or grey screen if your chime is turned off), hold down Command+S on your keyboard to enter single-user mode.
  3. Type mount -uw / and press Enter.
  4. Type launchctl load /System/Library/LaunchDaemons/com.apple.DirectoryServices.plist and press Enter.
  5. Type ls /Users and press Enter. This lists all of the usernames on the computer - helpful if you don't know or remember what these are.
  6. Type dscl . -passwd /Users/username password and replace "username" with one of the users displayed in the previous step. Replace "password" with a new password of your choice. Press Enter.
  7. Type reboot and press Enter.
Reset 10.4 Tiger password
  3. Type sh /etc/rc and press Enter/Return.
  4. Type passwd username and replace "username" with the short name of the user account for which you'd like to reset the password.
  5. Type your desired password and press Enter. It won't show itself on the screen, so be careful what you type. You will most likely have to enter it again to confirm.
  6. Type reboot and press Enter.
May 02, 2011 | Apple iMac 17" MA199LLA Desktop
I cant not login in too my users i forgot my password
Thank you for contacting Fixya Support, I am glad to assist.
If you are unable to gain access via the password to login to your Mac OS X desktop, you are going to reset your password.
What you will need to do is use the Mac OS X restore (Disk 1) or the Mac OS X installation disk which came with your Macbook Pro.
Now perform this process:
* Insert your install disc
* Reboot your Macbook Pro
* Press the C key on your keyboard and hold until you see the white screen, grey apple, and eventually the spinning gear.
* Release the C key when you see the spinning gear
* When you reach the Mac OS X install environment, click past the language screen.
* From the Installer Menu bar select "Utilities" and then "Reset Password".
* Within the Reset Password utility, select the User Account you need access to.
* Reset the password.
* Quit the Reset Password utility when you have reset and confirmed the new password
* Quit the Installer and restart your Mac..
* At the log in window, enter your username and newly reset password. You should now be able to successfully log in. * I hope this helps.
Regards,
-Mactechtrainer
Sep 13, 2010 | Apple iBook G4 Mac Notebook
Password problem
Here is a quick fix for resetting your Mac password.
1. Hold Apple+S when your Mac is booting to enter "single-user" mode.
2. Type "sh /etc/rc" without the quotes.
3. Type "passwd USERNAME" without the quotes, replace USERNAME with your actual Mac username you forgot the password to.
4. Reboot your Mac by typing "reboot" without the quotes.
Hope this helps.
Mar 29, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I forgot my password and username and i dont have the start up discs how can i use my computer?
It sounds to me like your very forgetful/unlucky or you stole this laptop. If you want to reset the password you'll need an installation disc. Or you could ask the owner for their username and password :)
Good Luck
Feb 23, 2010 | Apple MacBook Mac Notebook
Apple G3 starting problem
Resetting the original administrator account password Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
  2. Choose a language, click the arrow button to continue,
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note
    : The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
Feb 13, 2010 | Apple MacBook Mac Notebook
I just set up the password on my macbook to get rid of a network settings problem and now the computer is saying i am putting in the wrong password!!!! I powered off the computer and restarted thinking...
Ok well try this... Resetting a user's password in Mac OS X v10.3 or later
Note: For information about resetting a password in Mac OS X v10.2.8 or earlier, see the Additional Information section below.
    1. Enter a new password.
    2. Click Save.
    3. Click the red button in the upper left corner to quit the application.
    4. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
    5. Click Restart.
    After following these steps, you'll want to also follow the steps in this article.
Feb 06, 2010 | Apple MacBook PC Notebook
Switch D-Link DES3226 Lost Username and Password
Manufacturer can reset that with the mac add. and S/N. if it hasn't been set try leaving username blank and enter admin for the password
Feb 12, 2009 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
Motorola AP 6532 Access Point Logo
27 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
