Question about Thermador PRDS304US Dual Fuel (Electric and Gas) Kitchen Range
One igniter stopped working after a power outage. It doesn't click and doesn't emit any gas. Also, it isn't adhered firmly to the surface of the range. I'm able to pull it out from the surface. Iand can see it's attached to a wire underneath. It's been cleaned so that's not the problem. Please advise.
  • B Roth
    B Roth Dec 29, 2013
    That's not the problem. Thanks anyway
    New Friend:
    Problem Solver:
  • 13 Answers
Believe it or not these units need electricity to run. It sounds like it may have tripped the GFI. Look for a power outlet that has a red button. It may be out. Push it back in if it is.
Posted on Dec 29, 2013
  • B Roth
    B Roth Dec 29, 2013
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Re ignight
Believe that is hot surface ignition...so it should relight itself. turn the power off & back on, the power outage could have messed with the circuit board
Feb 21, 2013 | Amana GMH950453BX Gas Furnace
Spark igniter isn't stop sparkling.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 08, 2011 | Jenn-Air JDS8860BD Dual Fuel Range
Our Generac Generator 04675 (15 kW LP) ran for 3 days in a row due to a power outage. It shut off for low oil on the fourth day. We Added 1 qt oil and we restarted it and it ran great for another day...
The only time a battery will blow up is if the hydrogen gas ignites. Usually what happens is that when the battery is being drawn like during cranking, or trying to be recharged at a high rate the battery begins emitting hydrogen gas from the sulfuric acid. This is usually why the battery is kept away from anything that sparks usually. When the hydrogen gas comes out it also slowly bakes off pure water. When this happens and the level drops below the level of the plates in the battery, when the battery has to make amperage during cranking an ark occurs accross the plates igniting the hydrogen gas and making a miniature atom bomb. Loud isn't it?? To prevent this from happening keep an eye on the charge rates of the battery and if the battery has removable vent caps, keep the level topped off with distilled water. Please also note that many residential gensets do not charge their own battery and rely on the maintenance charger to always keep the battery charged. Make sure the maintenance charger is on a circuit that will be powered by the genset during a utility outage.
Jul 16, 2011 | General Electrical Supplies
Cooktop burner switches do not ignite when turned onn
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 15, 2010 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
I can't get one of my burners to light on my ge gas stove. It clicks and emits gas, but no flame.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 17, 2009 | Avanti G20AW-1 Gas Kitchen Range
We installed the car cradle to the windshield but receiver won't adhere to the disk. Please tell us what we did wrong. Thanks, Pat skillman
i think you mean the mount wont adhere to the disk..normally the disk is not used to mount the gps to the windshield, is more for the dash area or another spot where the suction cup wont adhere. the are rare occasions where the disk is needed for the windshield though, but its rare. try ataching it to the windshield without the disk. lift lever at suction cup, press the mount firmly against the windshield, then press the locking lever down to secure the mount. the picture below is the wount in the unlocked position.
form Magellan
This adhesive disk provides an alternative to mounting your Magellan GPS to the windshield of your vehicle. The disk adheres firmly to your dashboard or virtually any surface. Then attach the suction cup of your windshield mount to the disk.
Aug 14, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Water heater with electonic igniter will not work in power outage
What type of heater is this? I need to know the model name and make and then we can go threw the process of how to do it. Most gas heaters do not have power to them and I only know of a few tankless heaters that do.
Feb 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Electronic igniters Model SEG196
there is a spark module that controls all four surface burners usually located behind the rear access panel. This may have been a casulty of the outage. good luck
Jul 16, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
1 burner wont stop clicking on miele cooktop km 344
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
May 06, 2007 | Miele 36 in. KM342 Gas Cooktop
Thermador PRDS304US Dual Fuel (Electric and Gas) Kitchen Range Logo
116 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
