Question about Kodak Photography
I have a problem with my kodak foto kiosk gs compact. when i power it on screen displays " no input signal" cables in display are conected properly. its connected with kodak 605 photo printer. please help
Vas te fair foutre
Posted on Nov 27, 2014
ON SCREEN HAD POWER ONLY V8.02.8
FOLLOW this instruction and fix it. God bless you
Connect the component video, HDMI1 or AV1 cable from the component device (such a DVD player) to the appropriate input port on the TV. This port may say "Video IN" on the back of the TV. Ensure that the cable is connected securely at both ends.
· 2
Use the remote control's device button(s) to access the menu and select the input through the menu that matches the type of cable input connected to the back of the TV. For example, if you connect the cable to the HDMI1 input port on the back of the TV, selecting anything but the HDMI1 option with the remote control may cause the "No Display" message to appear, which usually means that the TV is not receiving a signal at the connection input you have selected.
· 3 Turn the power on to the component you want to view. If the power was off, turning it on will activate the display and replace the "No Display" message.
· 4
Test any other connected components at their selected inputs to see that the TV is receiving the video signal properly from those sources.
· 5
Check with your cable or satellite provider if their set-top box is the source of the "No Display" message and is powered on, to see if the problem is caused by a disruption in their service. If using an antenna, adjust the antenna and re-scan for available channels.
Jul 20, 2013 | LG 55LE5400 55IN LED HDTV 1080P 120HZ 4...
No signal. Power is on, cable functions well (tested on other computer). nevertheless, the screen does not work (any more) and shows signa " no signal" . What can have gone wrong with my screen...
The fact that you see the "No Signal" message indicates that the display is functioning properly. The problem is with the input section. Verify that you have the correct input selected. Other than that, the input board is the likely defective section. This is not uncommon and will require service. This is not likely to be a DIY repair if the input board is defective.
Dan
May 29, 2011 | iiyama Prolite E430 17" LCD Monitor
I have a apex 32-inch tv model (AT3208S), This tv was connect to a converter box, the other day electric power went out in our area for about 8 mins or less, once the power was back on the tv screen was...
OK, I have one of these TVs, and here's a thought: There's nothing wrong with the TV nor with the cable converter box. Please bear with me. Since I don't know how much you may know about TVs in general and this one in particular, I'm going to assume you know nothing and go from there.
This TV has several different "inputs", which are ways a signal can be transferred from its source to the TV, where it "outputs" the video image. I believe this particular TV has 5 different inputs: In descending order of the quality of the video signal, there're one S-video input (a 4-pin video connector plus red & white audio), three composite video inputs (3 connectors each: yellow video and red/white audio--audio connectors are the same for both s-video and composite), and one coax connector (a single large screw-on connector with a little wire sticking up through the center of it) for a total of five different inputs.
The problem with these Apex TVs is that they always default to the Antenna/coax input first when they are restarted. Most people use the TV to display an input signal (like the cable box or a DVD player) connected either to the S-video or to one of the 3 composite video inputs, not to the coax input, which just displays the channel numbers from 1-125 when it's set to do that (hit the "display" button on your remote to toggle showing the channel numbers for the coax input). If there's no signal coming into the coax input, the screen with appear blue. (If it's blue, it simply means it's not getting a signal via the input to which the TV is currently set. You can turn off the blue screen in the menu settings, but then you'll just get a blank screen. It's probably better just to leave the screen blue; at least you can tell the TV's actually trying to display something that way.)
You have to manually select the proper input by pressing the "video" button either on the remote (lower right corner) or the "video" button directly on the TV (hidden control panel under the middle of the margin around the bottom of the TV screen. You'll have to press on the door, and the whole control panel rolls open to reveal another set of composite inputs and some buttons. The video button is the one farthest to the left.)
Anyhow, by pressing the video buttons, you'll cycle through the various inputs. Assuming your cable converter box is functioning properly, powered on, receiving a signal from the cable company, and connected to the TV via a(n) appropriate wire(s) connected correctly, you should see the output from the cable box on the screen when you cycle through to display the proper video input.
Another possibility: the power outage fried the input to which your cable box was connected on the back of the TV. If that's the case, your cable box would probably also have sustained damage. You can check to see if the various video inputs on the TV are working by connecting different source inputs (like a BluRay/DVD/VCR player, video game console, video camera, etc.) to one of the other inputs and see if you get a picture when the TV is set to the appropriate inputs. (Remember, the "video" button is what selects/changes/cycles through the various video inputs.) One of the sets of inputs went bad on my TV. I just use the other ones.
May 18, 2011 | Televison & Video
I have a synaps monitor model mt9bbk. The screan will go black and power led will flash.
Display Power management is being triggered because no input signal was detected. Verify that the video source is connected and on. (Computer, notebook, etc).
- Try another computer or laptop that you know is working properly.
- Do you see any change on the screen if the display cord is completely disconnected (often a "Test" or "Check Cable" message appears). - Inspect the signal cable from the monitor - worn? Any places where the cable was bent to an extremely small (acute) angle? (less than 75 degrees?) Try gently moving the cable around at either end and see if you get a partial signal on the screen (while connected to the computer). If you do, the signal cable is damaged, if possible replace it. try: www.monoprice.com
Apr 14, 2011 | Computers & Internet
I cant see the menu on the tv, i conected an hdmi cable to the ouput where it says monitor out, and my tv doesnt reconize it.
On page 8 it says, "The on-screen display signals are not outputted from the HDMI MONITOR OUT".
Run a set of cable(s) from the Video- S-Video- or Component Video Out connectors to a compatible input on the TV.
Jun 09, 2010 | Denon AVR-1908
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Display
Can not display what? Video? It should once in vtr mode. If it still does not work are you still getting signal to the LCD when recording? Does it Show on the LCD when connected to final cut? If you are getting any signal to it, it is a setting, prob mess with the video out settings, if not hardware.
If you want to display the info, try turning title on also turn character display off and on.
Aug 23, 2008 | Sony DSR-25 Mini DV VCR
My monitor not turn on when the computar turn on to . and when you try to turn on the monitor its like flash for 1 sec and tune off to black . to turn the monitor on i need to prees the botten 30 time on...
First you sec your monitor power cable is not loos or power in properly if ok then you sec your monitor VGA cable is properly conect to your pc if ok then you disconnect your VGA cable in your pc then you power on your monitor and sec that youre monetor screen. show a masege or not masage like tiis : CHEEK SIGNAL CABLE or NO SIGNAL : if show this signal then you men your display card is not responding or monitor shows nothing then you meen your monitor is faulty then contact any monitor techenican and solve your monitor problem.
Jul 19, 2008 | Computers & Internet
Mitsubishi WD-62525 Input 480i
it is just saying what input you have it on and what level of hd your getting (480i 480p 720i 780p 1080i 1080p)
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Photography Logo
837 people viewed this question
Top Kodak Photography Experts
Michael Galve
Michael Galve
Bill Eager
micky dee
Are you a Kodak Photography Expert? Answer questions, earn points and help others
