SOURCE: I have Logik MI1006 and it will not play a sound
Please check charger, propoblly light on charger is flashing to. If yes you have to replace charger on new one or fix the existing. ( leroyek69 )
SOURCE: How do you set the clock and alarm on the Starlite
Setting the clock for the Ipod docking station
NP105CR
Press the set button 3 times until all the digits for the main clock are flashing. Press the skip forward and back button for hour and volume up and down for minutes. Press set button once to confirm and exit the setting menu.
866-387-2027 for manual
SOURCE: my cd's wont play and my ipod but radio works on my jvc kdr 520
Are you talking about just the audio coming from cd's and ipod? If so, are you using an amplifier? If you are using an external amplifier, you may be using the blue wire (power antenna remoter turn on) instead of the blue/white wire ( amp remote turn on) to turn the amp on. The blue wire turns off when leaving tuner mode, thus turning off the amplifier.
I recommend that you will post your question under
the correct category (personal radios).
You can also contact the store that you got it from to get the instructions.
