Question about Vehicle Parts & Accessories
Can I replace the big end bearings on a nm pajero 3.5ltr petrol without removing the engine?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 133 Answers
Hi stephen yes you can do this you all you need to is remove the sump, if it is to fight to get the sump off you can use an engine crane and undo the centre nuts on the engine mountings and lift the engine an inch but you should not need to
Posted on Dec 31, 2013
I need the big end torque on the Rocam engine please
A cheap shop manual will have this and much more. If you are in this deep you probably need one.
Sep 05, 2016 | 2000 Ford Ka
I want to know the torque specifications for a 4D32 mitsubishi engine ?
we have 4g32 cyl head stage 1 70-76 nm stage 2 run for15 mins stage 3 tighten 78-83 nm
main bearings stage1 24-27 nm
stage2 49 -54 nm
big end stage 1 15-17 nm stage 2 31-34 nm I hope this helps from Coloneus
Jun 07, 2016 | Mitsubishi Cars & Trucks
Hi i have daewoo matiz 800cc can you help me by giving me the torque settings for the big end bearing caps please
You are looking for the torque settings for big end bearings and main bearings on a daewoo matiz?
Main bearings torques on a Daewoo Matiz 800cc (1999)
Stage 1: 25-30 Nm
Stage 2: 55-60 Nm
Big End Bearings…
Mar 09, 2016 | Daewoo Cars & Trucks
1995 mitsubishi pajero can i change big end bearings without takeing motor out stuck out in the bush ?
How did you diagnose big ends as faulty?Sate model name & yearmodel,engine size.Were are u stuck?
Apr 28, 2015 | Mitsubishi Cars & Trucks
What is the torque setting for main bearing and big end bearing of a Toyota Yaris 1.0 1kr 3 cylinder?
Toyota Yaris Main and Big end Torques:
Tighten the main and big end bolts in sequential order and in steps two steps.
- Main bearings. Stage 1. 30 Nm.
Stage 2. 59 Nm.
- Big end bearings. Stage 1. 15 Nm.
Rotate further by 90 degrees.
Apr 09, 2015 | 2008 Toyota Yaris
What the torque settling on a 1.8spi vauxhall cavalier 1994
Cylinder head Renew bolts: Yes Tighten: 25 Nm Tighten: 90° Tighten: 90° Tighten: 90° Other engine tightening torques Main bearings Renew bolts/nuts: Yes Main bearings Stage 1: 50 Nm Main bearings Stage 2: 45°-60° Big end bearings Renew bolts/nuts: Yes Big end bearings Stage 1: 35 Nm Big end bearings Stage 2: 45°-60° Oil pump to cylinder block : 6 Nm Sump bolts : 15 Nm Sump drain bolt : 55 Nm Flywheel/driveplate :
  • Use new bolts and tighten as follows:
      • 1,4/1,6 = 35 Nm + 30° + 15°
      • 1,8/2,0 = 65 Nm + 30° + 15°
  • "Pot"-type flywheel = 65 Nm + 30° + 15°
  • Tighten drive plate to 60 Nm.
Clutch pressure plate : 15 Nm Crankshaft pulley/damper centre bolt : Use new bolts. Tighten centre bolt to 130 Nm + 40°-50°
Camshaft sprocket/gear : 45 Nm Camshaft/rocker cover : 8 Nm Inlet manifold to cylinder head : 22 Nm Exhaust manifold to cylinder head : 22 Nm Spark plugs : 25 Nm Lambda sensor (Oxygen) : 30 Nm Chassis tightening torques Front hub :
  • Tighten nut in three stages:
    1. 130 Nm
    2. Slacken off
    3. 20 Nm + 80°-90°.
Steering track rod end : New nuts 60 Nm Brake disc to hub Front: 4 Nm Brake caliper to carrier Front: 30 Nm Brake caliper/carrier to hub Front: 95 Nm Brake caliper/carrier to hub Rear: 80 Nm New bolts ABS sensor Front: 8 Nm ABS sensor Rear: 15 Nm Road wheels : 110 Nm
There you go pretty much covers everything hope that helps
Jan 11, 2015 | Vauxhall Cars & Trucks
Hi I need the torque settings for both the cylinder head and the bottom end bearings for a 1997 Toyota Prado (3.4litre petrol). Thanks
1997 Toyota Prado 5VZ-FE
Cylinder head bolts:
Tighten the cylinder head bolts in criss cross manner inside out, in four stages as under:
Stage 1. Torque the bolts up to 17 Nm.
Stage 2. 34 Nm.
Stage 3. Rotate all the bolts 90 degrees.
Stage 4. Finally rotate all the bolts further 90 degrees.
Main Bearings:
Tighten the main bearing bolts in two stages, as under:
Stage 1. 61 Nm.
Stage 2. Rotate the bolts further 90 degrees.
Big end bearings:
Tighten the big end bolt of connecting rods in two stages as under:
Stage 1. 25 Nm.
Feb 27, 2014 | Toyota Land Cruiser Cars & Trucks
Replacing big ends(bearings) on toyota corolla 1992
if you are only replacing piston big end shells , this can be done on most vehicles with sump removed , but if your bigend main bearings need to be relaced , take out the engine.which i would suggest any how , bodging doesn't always work out cheap.
Nov 14, 2013 | Cars & Trucks
2002 audi tt 225 bhp cranksharft torque settings
Crankshaft torque settings for 2002 Audi TT 225 BHP:
1. Main bearings: Renew bolts = Yes
2. Main bearings: Stage 1 = 65 Nm
3. Main bearings: Stage 2 = 90 degrees
4. Big end bearings: Renew bolts / nuts = Yes
5. Big end bearings: Stage 1 = 30 Nm
6. Big end bearings: Stage 2 = 90 degrees
7. Flywheel / driveplate = 60 Nm + 90 degrees (use new bolts / nuts)
8. Crankshaft pulley / damper centre bolt = 90 Nm + 90 degrees (use new bolts)
Nov 25, 2010 | Audi TT Cars & Trucks
I need the torque specs for the main and rod bolt for a 99 escort 2.0l engine
Main bearings Renew bolts/nuts No
Main bearings Stage 1 43 Nm
Main bearings Stage 2 85 Nm
Big end bearings Renew bolts/nuts Yes
Big end bearings Stage 1 15 Nm
Big end bearings Stage 2 90°
Jan 21, 2010 | 2004 Ford Focus
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
