Question about Problem Solvers Vehicle Parts & Accessories
My clutch stuck to the floor & I could not get it into any gear, when I lifted the clutch pedal with my foot, it bounced back & started working - what could be the reason for this? I was wondering if it needs 'gear oil', that is the only fluid I need checked but I'm not sure where the item is located on my car, I have a '05 Scion tc 5sp. Any suggestions would be appreciated, thank-you for your time.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Suspect a defective clutch master cylinder, throwout bearing/slave cylinder or both...
check the fluid would be the first sign of problems. fluid is low it's either leaking out or it's time for a clutch job
Posted on Dec 29, 2013
  • Albert HAMON
    Albert HAMON Oct 14, 2014
    I had that problem in an older car and I had to replace the clutch
My clutch goes all the way to the floor I have a standard Camaro 96 3.8
clutch pedals are suposed to go all the way to the floor , you sure you dont mean brake pedal (cus thats bad ! ) clutches should travel all the way to floor and release the "grab" of the engine about 2/3 down , this way they are more smoothly allowing shifting thru the gears and not jerking as you shift thru the gears , if clutch pedal does not start to "grab" the engines power by 2/3 off the floor and fully "grab"its power all the way up(slipping) ,and you have a hydraulic clutch (96's do) then the clutch disk may require replacement or there is a oil leak in the clutch/master/slave cylinder , look for small oil leaks from under car in area of foot pedals
clutches should be replaced as an assembly that includes , disk ,pressure plate, throwout bearing , with engine side clutch plate magnafluxed for heat cracks and any hydraulic oil leaks replaced or repaired
Mar 12, 2015 | 1996 Chevrolet Camaro
2001 406 diesel estate manual. 11600 miles. clutch replaced 2 years ago. normal everydare use it is all ok. recently was in heavy traffic for over 2 hrs. never out of 1st & =2nd gear. Engine temp just...
If the clutch is correctly adjusted, it will start to engage when releasing the clutch pedal at 1 in. off of the floor. When in Heavy traffic shift trans to neutral while at a stop, take your foot off of the clutch pedal to avoid overheating the release bearing
Jun 05, 2017 | Peugeot 406 Cars & Trucks
Manual transmission wont go in gear
You have a clutch slave cylinder failure and the reservoir is empty. Replace the slave cylinder and bleed the air of the system after refilling the reservoir.
Apr 07, 2014 | 1995 Ford F250
Clutch pedal staying down but there's plenty of fluid in resiviour
Probably bad clutch master cylinder and/or slave cylinder. I always replace both.
Oct 04, 2012 | Cars & Trucks
The clutch when depressed stays to the floor can pull back up with foot. cannot change gears but can start car.
the clutch cable has snapped.or the nipple on the pedal has failed,simple job to replace but awkward/fiddly toget to.
Feb 27, 2011 | 1997 Mazda 626
Started off with cluth sticking to floor.would have to pull clutch pedal back up with foot. truck would stick in gear. even with clutch fully depressed. seemed like spring had disconnected from clutch...
your clutch uses a hydraulic master and slave cylinder to disengage. It is likely that the slave has been leaking and the reservoir gone dry, thus allowing air into the system and reducing effectiveness. Check the clutch master cylinder reservoir (near the brake reservoir) fluid level. If low, also check the slave cylinder at the clutch for leakage. If leaking, replace the slave and bleed the system. If you need procedures or have more questions, please let us know.
Sep 25, 2010 | 1994 Nissan Pickup
My clutch pedal suddenly stuck to the floor but wont engage anymore. The cable seemed fine
As far as I can remember, the Jetta has a ball & socket linkage on top of the gearbox. This linkage eventually wear out & the ball will pop out of the socket thus giving you no clutch pedal.
Lift the bonnet & have a look on the right hand side of the engine, you should be able to see what I mean. Push the ball back into the socket & you'll get your clutch pedal back. Chances are the clutch will probably go again unless you replace the worn parts but they're a cheap enough fix.
Hope this helps, Stephen.
Oct 28, 2009 | 1997 Volkswagen Jetta
Grinding and very hard to shift, and now the shifter is stuck
how does the clutch pedal feel?..clutch out of adjustment,needs clutch job...kev-mn.
Dec 10, 2008 | 1995 Pontiac Sunfire
Vehicle Parts & Accessories Logo
102 people viewed this question
Top Problem Solvers Vehicle Parts & Accessories Experts
Kathleen Brown
Kathleen Brown
Sam Akber
Sam Akber
_-__-___-_
_-__-___-_
Are you a Problem Solvers Vehicle Part and Accessory Expert? Answer questions, earn points and help others
