Question about Weslo Cadence G 5.9 Treadmill
I have a Weslo Cadence 5.9 Treadmill. I moved and now the motor and belt won't run. Everything else including the dashboard runs okay.
The odometer even runs. It powers up, but the motor and belt do not run.
4 Suggested Answers
mohtwister
  • 37 Answers
SOURCE: Lost owners manual
try this: http://fitness.owneriq.net/manuals/mfg/weslo/cadence_450_model_no_wltl35520.html
Posted on Jun 02, 2009
SOURCE: i have a weslo cadence 845 treadmill and i lost the key.
use a magnet
Posted on Mar 23, 2010
SOURCE: I have a Weslo cadence 860 treadmill and have lost
We used a paint stick instead of the key - it fits quite nicely - didn't even have to modify the paint stick except cutting it down so it was shorter and my hubby shaved a bit off the side. We do remove it after the work-out however!
Posted on Feb 22, 2011
Weslo Candence 5.9 won't run after being moved
Check for any loose electrical connections between control panel and motor especially any plug together connections. Moving may he have loosened or unplugged one of these connections. Hope this helps.
Dec 29, 2013 | Weslo Cadence G 5.9 Treadmill
Belt motor
see the video attached . Lube the rollers bearing front +back too.
God bless you
Sep 27, 2013 | Weslo Cadence G 5.9 Treadmill
Belt doesnt run
see the video how to lube the deck belt.
2) LUBE the rollers bearing too
3) Test the drive belt motor,
4) Test the input voltage motor, if there are the motor need repair see my personal TIPS for troubleshooting help
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram
God bless you
Nov 30, 2012 | Weslo Cadence G 5.9 Treadmill
How to replace the walking belt on Weslo cadence dl15 Treadmill
Installing An Icon Fitness Treadmill Belt- No Exposed Roller Bolts
You can save yourself a great deal of time by following these instructions as opposed to those of the manufacturer. Please contact us if you need any further help. UNPLUG THE TREADMILL BEFORE DOING ANY REPAIR!
Step #1- Before unfolding the treadmill, disconnect the lift shock from the ball joint. Most have a small retainer clip that can be pulled with a small flathead screwdriver and then the shock can be removed from the ball stud.
Step #2- Unfold the treadmill and then remove the three wiring connectors for the incline motor and then one of the incline motor mounting bolts.
Step #3- There are two shoulder bolts that hold the entire motor tray in place. These are at the back of the motor area and must be removed to gain access to the front roller bolts. Remove the two shoulder bolts and then you can pull the motor tray slightly forward or backward to gain access to the roller bolts.
Step #4- Follow the replacement instructions included with the walking belt.
Step #5- Reverse the process of step one, two, and three to reassemble the treadmill.
http://www.treadmilldoctor.com/installation?utm_source=fixya&utm_medium=cpc&utm_campaign=mendi
Jun 26, 2012 | Weslo Cadence Dl15 Treadmill Walking Belt...
Walking surface will only move very slowly. The belt seems tight enough, tried to tighten 1/4 turn, still not moving properly. Treadmill is a Weslo Cadence 450, bought a few years ago. Thanks
lift the sides of the w/belt the hieght should be 2-3 inches. if more to loose,tighten it up. still have a issue take hood off and check the motor belt. if you find a bunch of black dust. your belt is worn or on its way out.PS you can find the belt on the web.
Mar 09, 2011 | Cadence Exercise & Fitness
Safety key is inserted into weslo treadmill cadence 825 but belt wont move, it worked for about 5 minutes before it just stopped, felt like belt was slipping, rollers at either end not moving.
hi if you can take off the front pannel where the motor is. its look like the belt on the motor a either slipped off or you need a replacement,
Nov 15, 2010 | Cadence Exercise & Fitness
Shuts down after running a few minutes
hi when you mean shuts down it that the power or just the belt, if everything including the power turns off then check the trip switch on the front of your treadmill, and if you are using an extention wire on a roll, please unroll the whole thing that can cause a short. and if you can smell any burning thats a sign that the motor and belt are either too tight and on they way out.
Nov 12, 2010 | Cadence Weslo 620/630 Treadmill Walking...
Weslo cadence treadmill wont work
I centered the belt on my tredmill and now it wont move at all. I tighted and loosened the belt. motor runs belt wont move
Feb 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Weslo Cadence G 5.9 Treadmill Logo
43 people viewed this question
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
