Question about Galaxy Aqua 2000
How to remove cover to replace shower hose - Galaxy Aqua 2000
My mira elite 2 shower is leaking,The flow and tempt is ok. but the leak has got worse and it is cold water the leak is not from the hose that is connected to the shower head. It only leak when its on
Please use plumbers white tape wrapped in a clockwise diection. Tighten and let us know Geraldine. Thank you and send us a picture if you can. Best of luck leave feedback
Jul 13, 2016 | Home
My mx inspiration lxl as a leak from the overflow pipe behind the shower hose it only leaks when turned on this only happened when I changed the shower hose I had to take the shower cover off to do yhis
u need to change the Black Leather Circle, it comes between the shower hose and the pipe!! also check the shower hose from inside you may find some small stones and sands inside!!! i had this before and fixed it the exact same way i told you :)
Jun 08, 2014 | Home
How to fix bathroom shower faucet
shut off water to shower, remove knob by popping cover off and removing screw, remove valve cover by just pulling straight out. there will be a retaining clip that holds cartridge in you will need to remove, Pull out old cartridge and replace with new.
Feb 21, 2014 | Moen 3175 Legend One Handle Shower Faucet...
Low water pressure - I removed the shower head from the hose. The hose from the wall to the shower head has a filter. How do you change or clean out the filter? I suspect the filter is...
unscrew the the big part of the shower head. if it is difficult it may have been put on there too tight. lowes has replacement filters.
Dec 04, 2010 | Home
Can the hand-held shower hose be replace without accessing the plumbing underneath the tub? I can't figure out how to disconnect the existing hose from the diverter without cutting an opening under the...
No, you need to cut a hole. Usually an access panel is provided during the initial installation, either in the ceiling from downstairs or in the other side of the adjacent wall. But it's pretty easy to add one. After you cut a nice rectangular hole, you can cover it with a piece of painted plywood that has a trim piece attached to the plywood. The plywood is held in place with a couple of screws. When you remove the panel, the trim stays attached to the plywood. When you place the panel in the hole, the trim covers the gap between the drywall and the plywood.
Dec 01, 2010 | Grohe 25 597 Talia Tub Filler w/Personal...
Remove and replace a hand held shower head hose in whirl pool
Hey Rick........the connectors are just large nuts at each end of the hose. If you remove one of the connectors there should be a a ring slipped around a grooved part of the hose with a plate. If you remove the clip the plate should slide off enabling you to remove the hose. Let me know if you need any more help.
Thx
Ken
Aug 16, 2009 | Price Pfister Roman Tub Hand-held Shower...
The shower hose leaks from the connection between shower hose and
have you tried teflon tape? wrap it around about 7 times and you will be fine.
Jun 24, 2009 | Grohe Movario 59" Metal Shower Hose -...
Water pressure to main hose has ceased, with water now pouring out of a small outlet pipe at bottom of unit next to fixing for main hose.
Sounds like your outlet at the top has clogged with grit/dirt. Turn the shower off, remover the entire shower head hose from its base (where it screws into the wall or pipe. Turn water back on. If you get a steady flow (as you should) the problem is isolated to the shower head/hose. Detach the shower head from the hose and clean the screen inside, attach hose back on first, try water again, if this flows then your blockage is in the head itself. After removing and cleaning the screen inside the shower head, reattach and run water, this should fix your problem, if not, you may need a new shower head. If the water will not flow to the outlet pipe alone, either your shower switch is broken or you have a serious plumbing problem.
Apr 16, 2009 | Home
Galaxy Aqua 2000 Logo
Top Galaxy Home Experts
Tom Chichester
FixIt_Right
S Sigs
S Sigs
Are you a Galaxy Home Expert? Answer questions, earn points and help others
