Question about Canon IMAGERUNNER 2230 Copier
IR c3080i copier displaied error code E000990-000
guru_dev
  • 315 Answers
SOURCE: error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Posted on Jun 01, 2009
redzventures
  • 149 Answers
SOURCE: IR-2570CI
This error indicates that the patch image read sensor is dirty. You can locate the patch sensor by removing the drum unit from the front of the machine. The patch sensor is located in the machine, directly above the drum unit, halfway intothe machine. If you look into the machine and up you will see a white plastic unit running along the top about halfway point between the front and back of the machine. The patch sensor is inset into that unit and is black plastic. Clean with a lint free cloth several times - as it is hard to see the actual sensor, feel along the strip with your fingers until you can feel the indent where the sensor is - concentrate your cleaning around that area. Now replace the drum and turn the machine back on (I hope you turned it off first).
Removing the drum is easy but hard to explain. In fact, if you get the front cover off, you've done the hardest part. There are some hidden screws, one above the front cover to the left - as if you are looking down on the machine, there may be a small circular plastic cover hidding access to this screw. Remove it and unscrew. If you have an internal finisher, you will have to remove the circular covers above and below the front of it to push your driver through to the hole you need. Sounds complicated but once you've done it you'll see that it's easy when you know where the holes are. There is then another screw at the top, near to right that you access through the panel above - just look around and above the front cover to find the screws. Good luck
Posted on Aug 30, 2009
SOURCE: Canon IR C6800 Error 00003-0042
E000012-0001
Posted on Nov 20, 2009
canontech
  • 1219 Answers
SOURCE: my copier is canon ir 1600 and it have system error
wich system error?Is it 001, E100, E019?
Posted on Feb 25, 2010
SOURCE: USA - COPIERS - IMAGERUNNER 2230 Copier: canon IR 2230 r giving me an error E000024-0001...
eroor 000024-0001 error is found in cannon ir 2870 machine, how is solve the problem
Posted on Aug 25, 2011
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
Nov 05, 2015 | Office Equipment & Supplies
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
Canon iRC 3380i error code E00025-002...help please?
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Jun 15, 2010 | Canon C3380i Color Copier
IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Jul 06, 2009 | Panasonic WORKiO DP-2330 Copier
61 people viewed this question
old marine
old marine
