I have a WWA8827MALWH top load washer and the temperature settings dont match what they are supposed to be. i cant seem to get a cold/cold wash.and the other settings are mixed as well
  • 864 Answers
Make sure the cold and hot water hoses are connected to the appropriate ports?  Also check to see that the filter screens in the hoses are not clogged.
Posted on May 20, 2009
How do I set water temperature for the rinse cycle?
I suppose you have looked at the owners manual, on the page below, it seems to indicate knob B. but it is unclear
GTWN4250DWS GE 3 9 DOE cu ft stainless steel capacity washer GE Appliances
Dec 24, 2014 | GE GTWN4250DWS 3.9 cu. ft. capacity top...
Washer over flows wont agitate on all load sizes will spin out water runs both hot and cold water on all settings from tap cold to hot timer doe not seem to move
we have a pressure switch problem...replace pressure switch,,,i dont understand what a cold to hot timer is,,,i assume you me water temperture switch...
Sep 02, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
I have my machine setup through my faucet. In the manual it says to hook it up to the cold water connector. My question is when I am going to wash hot water am I suppose to connect to hot water connector...
I am assuming that it is cold fill only in which case you leave it on the cold supply. The machine will heat the water to the correct temperature for the wash selected ;-0)
Cheers,
John C
Mar 20, 2011 | Avanti 10 lb. Portable Top Load Clothes...
Hot water seems to not enter tub during washing cycle. all connections are correct and the hot water hose is hot up to the back of the washer, im baffled ? does the unit start with cold water on the first...
They start with hot or warm ,what/ever the setting and rinse with cold water. Check the temperature adjustment and the cycle it's on as some do different things on different cycles.
Dec 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I can't set my Neptune washer temperature to cold water wash. I press the HAND WASH button which originally used cold water but now it stays on hot water (highest temperature setting). the arrows where you...
you need to call your parts store or the factory number in your book,give the model and serial number to them and order the console,the touch pad is damaged and they sell you the whole top console on the washer
Feb 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water setting temperatures are off
It would say that it should be under warranty.But this model has parts that are no longer availible. Here is my guess, you have a bad switch.
Part number PS1491292
on this web site http://www.partselect.com/
Please rate solution
Aug 24, 2009 | Whirlpool LTE6234D Top Load Stacked...
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
Jan 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
