Question about HP Officejet J5780 All-In-One InkJet Printer
Broken Hinge I want a a replacement part for the HINGE.
    New Friend:
    Problem Solver:
  • 6 Answers
Howto solve 50.2 fuser error for cm2320
Posted on Dec 29, 2013
Puppet03
  • 172 Answers
SOURCE: Hinge for the Cartridge Door will not latch. Seems
good old duck tape ;) or go to a print repair shop and see if they have and parts for you.Ink shops sometimes do there own repairs too so try there
Posted on Oct 24, 2009
Testimonial: "Thanks I did not know the Ink shops could do repair. "
  • 11 Answers
SOURCE: left hinge is broken on HP officejet 6210
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Posted on Jun 13, 2010
  • 11 Answers
SOURCE: Can I get parts to replace broken hinge?
  • 3 Answers
SOURCE: left and righ hinge is broken on my HP officejet
I "inherited" a 6210xi because BOTH hinges were broken... poor and weak plastic design that breaks if the operator tries to raise the access past about 40 degrees for access to ink cartridges... of course after the hinges break it doesn't close properly to start again (except with creative taping!). In my pursuit of these parts I found that the lower hinge part (broken) Part#JB6100289A is actually a Samsung part for their SCX-15 printer/scanner. It was also interesting to find several of these 6210xi's for sale on eBay and other places for $10 or less as "broken, parts only" and AMAZINGLY, it was the same broken hinge part that put all of these out of service. Found the HP Part number as RG5-6317-0000N but couldn't find anything except to buy either the Top half of a whole 6210 or the Bottom half for hundreds of $$'s, far more than the WHOLE new working item would be. UED.net listed the part as "non-stocking" at $2.27 each, available Aug 8, 08, but it turned out to be that they are negotiating for access to that parts and VIOLA! a few months later I received SIX hinges at $2.27 each plus shipping. You have to be creative to keep your old stuff working.
Posted on Jul 06, 2010
  • 3 Answers
SOURCE: Broken hinge
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
Posted on Aug 12, 2010
How do I fix or replace a broken Hinge on Dell 500 Laptop
The hinge rarely breaks, the fixings come loose and split the plastic case.
Disassemble the laptop to find out where your problem is,
DELL Vostro 500 PP29L SSD
If the plastic has broken off, I use epoxy resin to repair around the hinge or look on fleabay for a replacement hinge.
Dell Latitude D500 Laptop 14 1 034 Screen Hinges eBay
Feb 06, 2017 | Dell Computers & Internet
CAN I REPLACE A BROKEN HINGE TO A HP 2140
Yes you can.
These WEB sites shows how.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Dec 07, 2012 | HP Mini 2140 Notebook
Easynote te 11 broken hinge
Check out these WEB sites for assistance.
Oct 02, 2012 | Computers & Internet
Left hinge is broken on HP officejet 6210
Nov 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hinges for top cover for HP officejet 6210- Q5820A
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
Nintendo ds broken hinge.
donde puedo localizarlos para llevarles el nintendo ds
Nov 22, 2008 | Nintendo DS Console
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
8820DN hinge problem
To answer Meyerson's questions:
My symptoms did not include papers jamming in the ADF -- in fact, the ADF didn't work at all due to the broken left hinge.  :(  Also, I don't recall having any unusual problems with the ADF jamming frequently before the hinge broke to the point where the ADF didn't work at all.
I obtained the replacement ADF left hinge assembly by searching online for a parts dealer.  I believe I ended up ordering the part from Precision Roller.
I hope this helps,
-Barb
Apr 01, 2008 | Brother MFC 8820D All-In-One Laser Printer
Broken screen hinge/collar
You can purchase replacement hinges and hinge covers here: http://www.mundocorp.com/m275.html They may be a bit of work to replace. But short of replacing the hinge assembly, it doesn't sound like that is going to move.
Aug 28, 2007 | Gateway M275 Tablet PC
HP Officejet J5780 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
