Question about Coffee Makers & Espresso Machines
Problem saeco sg200 selection
Hy.my name is dan. i am from romania.i have an saeco sg 200... and i have a problem with 5th selection (cappuccino with coffee - OK BUTTON FROM MENU)...doesn.t work...all others products works. from menu i give price for five selection, i set available and set the prepairing mode (0 c 2 3)... beverege check from menu work's but other way doesn,t ...the button work because i can select options from MENU ...i try all resets! no error found....before this problem, chocolate and milk mixer - burned!!!any advice??? PS sorry for my english THANK YOU!!
4 Suggested Answers
SOURCE: Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Posted on Oct 30, 2008
  • 20 Answers
SOURCE: Change milk temperature (milk not warm enough)
It all depends in the Cappuccinotore(milk frotting part) Change a new one or
Think of a way to reduce the suction tube diameter smaller... to get milk and steam mixture correct.
Posted on Aug 14, 2009
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
make sure you use very dry non-oily coffee beans
Posted on Jan 31, 2011
Hi, I have a Saeco Primea Touch Plus, in the display it says error 5. What ca I do? Regards, staffan
I had that error too, the very first day after i received my Saeco Primea Cappuccino Touch Plus from Germany. The curiosity is that the machine was able to prepare a cuple of cups and suddently died with 5 in screen. Going to the service, they said that error 5 is about a lack of pression in pipes, probably due to the unprotected transport to Romania. I don't know if they fixed alsi some jonctions, but i had to pay for few rings. Everything took a day in service, but now is working fine. Hope it was usefull and my english enough inteligible.
Apr 17, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
The ventilate notification doesnt disappear on my saeco royal cappucino even i flushed with 4 loads of water
Please release hot water as well as steam by selecting both the selector switches( press hotwater button and open the steam knob).
Still you have the same problem,better you have to consult with service technician( there may be problem with boiler section)
Jul 24, 2010 | Saeco Royal Cappuccino Espresso Machine
I need an owners manual for the Saeco Royal Cappuccino machine? SUP016R manufactured in 6/2006
Scroll down this page:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
You can download the manual for your Saeco Royal in a PDF format.
Hope that helped! Thanks for using FixYa.
Jun 10, 2010 | Saeco Royal Cappuccino Espresso Machine
Saeco cappuccino royal wont steam or ventilate
Hi
You have a stuck solenoid or a plugged stream tip.
May 23, 2010 | Saeco Royal Cappuccino Espresso Machine
My Saeco Primea Cappuccino has stopped dispensing milk but no error is displayed
If you don't perform the milk cleaning process for 21 days, the machine will blocked you from dispensing milk product.
Apr 16, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Where can I find user manual for saeco magic espresso cappuccino maker
Send a request to info@espressotec.com . You will be sent the manual. confirm if helpful.
Jan 01, 2010 | Saeco Magic Cappuccino Espresso&Cappuccino...
Saeco Primea Cappuccino brewing very slowly
Try to descale the machine.
Try to adjust the grinder little.
/Mirran
Aug 21, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Are there any published example beverage settings for Saeco 8p expresso vendings Eg, Recipe for cappucino & latte
what kind of recipe do you want to know.Cappuccino is Made from Latte and Coffe.Sturbucks is not Cappuccino..Originally the name cappuccino came from COFFE(BLACK) AND MILK(WHITE).Both togheter give the color called CAPPUCCINO.In so many years the cappuccino found different way to make it work....caramel,coccoa,nutmeg....The good recipe and famus still the regula cappuccino with sweet or unsweet coccoa on the top of the foam.
Apr 19, 2008 | Saeco Incanto Classic Espresso Machine
Water size selection!
Do you have a trim pot on your machine or just buttons?
Apr 15, 2008 | Saeco Trevi Automatica Cappuccino
Loud noise
Not sure I understand ....is the pump making a lot of noise?
If so it might have sucked in some air. Run some water through your steam pipe until all the air has been pushed through.
Jan 08, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Coffee Makers & Espresso Machines Logo
14 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
