Question about Coffee Makers & Espresso Machines
Problem saeco sg200 machine
Hy.my name is dan. i am from romania.i have an saeco sg 200... and i have a problem with 5th selection (cappuccino with coffee - OK BUTTON FROM MENU)...doesn.t work...all others products works. from menu i give price for five selection, i set available and set the prepairing mode (0 c 2 3)... beverege check from menu work's but other way doesn,t ...the button work because i can select options from MENU ...i try all resets! no error found....before this problem, chocolate and milk mixer - burned!!!any advice??? PS sorry for my english THANK YOU!!
SOURCE: Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Posted on Oct 30, 2008
SOURCE: Saeco aroma compact SE 2GR turns on, but only heats the water.
I had replace my on off rocker switch on my aroma nero after a couple of years I was able to swap out my switch for heating the steam as a temporary fix I purchased a replacement switch from Sacco at that time but I think now you might have to go to a secondary parts dealer I have kept this machine a live for over 12 years and am now going back to it after fighting with my new automatic machine sure it was easy but the taste just was not the same the kids can have it they put so junk in their coffee how would they know pbjh2o@yahoo.com
Posted on Nov 22, 2009
  • 1089 Answers
SOURCE: Saeco Royal Professional is stuck on "Ventilate"
Hi
There are possibly 2 things that it could be.
1. Check that the tip of the wand is not plugged.
2. Your solenoid valve that controls the water is bad or stuck. That means a trip to the service center.
Posted on Apr 19, 2010
SOURCE: milk is not dispensing hot enough from saeco
If you use cold milk, I don't think it has enough heating power to make it hot enough. What I find works best is using long life milk from a carton which is room temperature, or making the milk room temperature warm in the microwave first before pouring into the milk containter
Posted on May 08, 2010
  • 1089 Answers
SOURCE: Hi all, I can't get
Hi
Push the menu button. If it says warming up, then push it again. Then use the up, down arrows to scroll to the item you want to change. With the astrick(*) in front of the item, push the menu button again. Use the up, down arrows to change the item to what you want. With the astrick in front if the sub item, push the menu button to make it the selection you want. If you don't push the menu button it will remain the same as it was. Push the escape to exit.
Posted on Apr 14, 2011
Hi, I have a Saeco Primea Touch Plus, in the display it says error 5. What ca I do? Regards, staffan
I had that error too, the very first day after i received my Saeco Primea Cappuccino Touch Plus from Germany. The curiosity is that the machine was able to prepare a cuple of cups and suddently died with 5 in screen. Going to the service, they said that error 5 is about a lack of pression in pipes, probably due to the unprotected transport to Romania. I don't know if they fixed alsi some jonctions, but i had to pay for few rings. Everything took a day in service, but now is working fine. Hope it was usefull and my english enough inteligible.
Apr 17, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
The ventilate notification doesnt disappear on my saeco royal cappucino even i flushed with 4 loads of water
Please release hot water as well as steam by selecting both the selector switches( press hotwater button and open the steam knob).
Still you have the same problem,better you have to consult with service technician( there may be problem with boiler section)
Jul 24, 2010 | Saeco Royal Cappuccino Espresso Machine
I need an owners manual for the Saeco Royal Cappuccino machine? SUP016R manufactured in 6/2006
Scroll down this page:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
You can download the manual for your Saeco Royal in a PDF format.
Hope that helped! Thanks for using FixYa.
Jun 10, 2010 | Saeco Royal Cappuccino Espresso Machine
Saeco cappuccino royal wont steam or ventilate
Hi
You have a stuck solenoid or a plugged stream tip.
May 23, 2010 | Saeco Royal Cappuccino Espresso Machine
My Saeco Primea Cappuccino has stopped dispensing milk but no error is displayed
If you don't perform the milk cleaning process for 21 days, the machine will blocked you from dispensing milk product.
Apr 16, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Where can I find user manual for saeco magic espresso cappuccino maker
Send a request to info@espressotec.com . You will be sent the manual. confirm if helpful.
Jan 01, 2010 | Saeco Magic Cappuccino Espresso&Cappuccino...
Saeco Primea Cappuccino brewing very slowly
Try to descale the machine.
Try to adjust the grinder little.
/Mirran
Aug 21, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Are there any published example beverage settings for Saeco 8p expresso vendings Eg, Recipe for cappucino & latte
what kind of recipe do you want to know.Cappuccino is Made from Latte and Coffe.Sturbucks is not Cappuccino..Originally the name cappuccino came from COFFE(BLACK) AND MILK(WHITE).Both togheter give the color called CAPPUCCINO.In so many years the cappuccino found different way to make it work....caramel,coccoa,nutmeg....The good recipe and famus still the regula cappuccino with sweet or unsweet coccoa on the top of the foam.
Apr 19, 2008 | Saeco Incanto Classic Espresso Machine
Water size selection!
Do you have a trim pot on your machine or just buttons?
Apr 15, 2008 | Saeco Trevi Automatica Cappuccino
Loud noise
Not sure I understand ....is the pump making a lot of noise?
If so it might have sucked in some air. Run some water through your steam pipe until all the air has been pushed through.
Jan 08, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
