Question about Pioneer DEQ-9200 3-Band Car Equalizer
My pioneer deq-9200 equilizer keeps resetting to default settings whenever i start my engine. What's going on here?
  • bullockandy May 19, 2009
    The unit only resets when i start the engine, not when i turn off the key or switch the head unit off.The Yellow wire is connected to the 12v constant and the red one is connected to the remote line of the head unit. Is there an internal backup battery that keeps the settings? Could my car battery be too low as it resets when i start?
    Thank you very much sphynkter, you nailed it. I think need to get a new battery.
  • 221 Answers
The EQ has two power wires on the back like a head unit. One is constant power, and the other one is ignition/switched power. This normally happens when the installer takes the switched power and applies it to both power leads going into the EQ or head unit. The EQ needs the constant power line run to a 12V source that never turns off. The constant power line is normally yellow, and the switched power line is normally red.
Posted on May 19, 2009
  • Sphynkter
    Sphynkter May 19, 2009
    Where is the constant power for the EQ coming from? Did you run a separate wire for 12V? or did you steal it from some other device? No, there's no battery in the EQ for settings, it just relies on the 12V constant. My guess is that when you start your engine, your starter/ignition system steals too much voltage from your EQ and causes the EQ to think it's lost power for a split second. Here's a test - have your head unit and EQ running in accessory mode for a short while, then start the engine but watch the face of the EQ. If the EQ shuts off and goes black - it's a low voltage problem. Your battery may not be holding enough of a charge to maintain the EQ and start the engine. You can try running a direct line to the EQ (with a small fuse of course) and see if that helps. Next step is to get a new (and maybe bigger) battery.
The equalizer has a 3 day backup "battery" in the brain of the unit. It's actually a 5.2v capacitor (.22F) that looks like a watch cell battery. You can order them on digikey, and they have the pos and neg connector already attached. A little fine soldering and it's restored to maintain the memory for the amount of time specified.
As I don't have the exact part number, I wouldn't call it an answer. However, knowing the above, you would need to pull the brain out, open it, and correctly identify the piece anyway.
This worked for me.
Posted on Aug 25, 2009
My head unit resets settings when key is taken out
Do you have the yellow wire going to a constant 12v power source? The yellow wire controls the memory of the radio and needs to have 12v going to it at all times, even when the key is taken out of the ignition.
Jun 28, 2012 | Pioneer DEQ-9200 3-Band Car Equalizer
Upon installing deq 9200....a humming sound exist as i pedal my gasoline
Check your ground wires. Power and audio need to be ran on opposite sides of the vehicle. Try re grounding the radio the a new location. make sure all grounds are connected to bare metal.
Feb 17, 2011 | Pioneer DEQ-9200 Universal Audio Processor
My pioneer deq 7600 keep resetting it wont memory
do you have the yellow wire going to a constant power source??
Sep 24, 2010 | Pioneer DEQ-7600 15-Band Car Equalizer
I have a deq-9200 one day it just shut off, I've tried everything, fuses , etc.i dismounted the central part (not the display) and noticed there was a liquid that leaked. Any suggestions?
Check the capacitors near the leak source if they vent ie swell on top then it is possible they have split causing fluid leakage they will not be far from leak on pcb replace the ones that look swelled
Jan 06, 2010 | Pioneer DEQ-9200 3-Band Car Equalizer
I have a Pioneer DEQ-9200 DSP Audio Processor
are your power wires and your rcas on oppsite sides this may be your problem
Oct 27, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Whenever i change setting it doesnt save when i switch of my car
the clock probly doesnt stay set either. the constant power wire needs to be hooked up to keep the memory. take it to a shop if you dont know what you are doing because you could mess up your cars wiring if you hook up the wrong wires. Good luck
Oct 07, 2009 | Pioneer Car Audio & Video
I'm searching for a visual diagram to show the power hook up on the Pioneer DEQ 7600. I need a description of each wire and how to connect.
go to crutchfield.com and type in your model.on the right side of the screen it lists whats in the box.from there you can print a diagram.
Sep 06, 2009 | Pioneer DEQ-7600 15-Band Car Equalizer
DEQ 9200 does nothing but blink
check your remote and ground source make sure remote power have enough ampirage for signal source that can cause it to blink
Jun 28, 2009 | Pioneer DEQ-9200 3-Band Car Equalizer
Pioneer DEQ-9200 3-Band Car Equalizer Logo
702 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
