MY hotpoint aqualtis keeps saying can't fill with water when it is filling with water but won't stop filling up. how do i reset machine
  • 1028 Answers
SOURCE: my hotpoint washing machine doesn't stop filling up with water
remove front cover by sliding putty knife along top edge and pressing down on clips pull front off ck small hose attached to tub on left side look for a dark build up in tube pull off and clean..blockage will cause water level switch not to sense full tub of water..if tub just never fill ck drain hose for correct height from floor and loose fit in standpipe
Posted on Dec 22, 2008
barkencoa
  • 3463 Answers
SOURCE: Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
Posted on May 11, 2009
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
Wood Chuck
  • 29 Answers
SOURCE: washing machine doesn't stop filling with water
Water level sensor could be bad.
Posted on Sep 15, 2009
SOURCE: Hotpoint aqualtis giving H20 error
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Posted on Jan 11, 2010
WASHER WON'T FILL WATER
Check to be sure the drain line is higher that the tub of the washer. You have a siphon going on the drain.
Nov 05, 2012 | Hotpoint Washing Machines
H20 is flashing on hotpoint aqualtis
This is a fill error, you need to make sure thee is adequate water pressure and that the inline filter in the inlet hose is not blocked.
Mar 06, 2012 | Hotpoint Washing Machines
I have a hotpoint aqualtis and i have a fault come up code fo5
F-05 is indeed the water outlet blocked. You need to clean it out, also possibly the pump, & Hoses.
http://www.howtomendit.com/answers.php?id=157950
See above.
http://appliancejunk.com/ge/washer/31-9135.pdf
Service manual above.
Aug 06, 2010 | Hotpoint Washing Machines
Hotpoint aquarius drum fills to top with water
will it stop when you stop the cycle? if so your pressure switch could be the problem however if that does not stop the water you intake water valve is most likley the problem
Feb 06, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aqualtis giving H20 error, looks like fill problem, but cannot see anything stopping the water flowing into the machine.
Dec 04, 2009 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
How do you replace a belt on a hotpoint aqualtis washing machine as the motor does not appear to have a bolt that allows movement and belt is very tight?
The belts that come on a hotpoint aqualtis washing machine is a stretch belt there is no adjuster for it but there is a little trick. TO HELP YOU SOLE THIS YOU NEED A BOWL AND A KETTLE. FIRST FILL THE KETTLE WITH WATER THEN PLACE YOUR BELT IN THE BOWL AND ONCE THE WATER HAS BOLIED POOR THE HOT WATER IN IT LEAVE IT FOR 5 MINS THEN TAKE THE BELT OUT BUT BE CAREFUL NOT TO BURN YOUR SELF NOW GRAB THE BELT AND PULL IT BY THE BOTTOM AND THE TOP BY DOING THIS BELT STRECHS ENOTHGH TO FIT ROUND THE FLYWHEEL AND MOTOR ALWAYS HOOK THE BELT FROM THE MOTOR FIRST THEN ROUND FLYWHEEL I RECOMMED WEARING GLOVES WHEN DOING THE JOB KEEP ME INFORMED ON HOW IT GO'S NOFFIE......
Apr 08, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
