Question about Rotary Watches
When i press the reset button on the big second hand it resets to 5 seconds on passed the normal 12 hours start position . how do i reset it please, its the rotary chronospeed gbo3351/05 (12949). thank you
SOURCE: Ta Heuer Professional stopwatch minute hand reser to 12 position
pull the crown on first click and push the upper button until it reaches to your desired position.
Posted on Mar 20, 2008
SOURCE: I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Posted on Jan 12, 2009
escapement
  • 2334 Answers
SOURCE: Techno Marine MO4 Watch, Seconds hand doesn't reset to top cente
You do not need to return the watch. It has self adjusting features (operated by the owner). Pull out crown to the first click, then push and hold the pushbutton at 2 o'clock to adjust the hand. When done - push crown back in.
If it doesn't work, pull out crown to the second click and do as described above.
Rate me, please.
Posted on Mar 22, 2009
escapement
  • 2334 Answers
SOURCE: The second hand on my luminox 8150 does not reset to 12 o'clock
Pull out crown to the first click. Push and hold pushbutton at 2 o'clock till the seconds hand reaches desired position. Push the crown back. You may need to operate pushbutton at 4 o'clock instead of pushbuttton at 2. Try both.
Rate me, please.
Posted on Mar 23, 2009
  • 18 Answers
SOURCE: Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Posted on Jul 09, 2009
How do i set both times i cant fugure out how to sync the digital to the clock
Here is what it says to do if the hands don't match up with the display time (usually happens after you change the battery).
First, you must locate the buttons on the watch.
The "A" button is at the 2 o'clock position (upper right). The "B" button is at the 10 o'clock position (upper left) The "C" button is at the 8 o'clock position (lower left) The "M" (mode) button is at the 4 o'clock position (lower right), and is the only button you can pull out to set the times, calendar and programming.
To RESET the watch and do the ZERO POSITIONING after changing a battery or having a display error, do the following.
RESET 1. Pull the "M" button out to the setting position. 2. hold down the "A", "B", and "C" buttons simultaneously for 3 seconds, then release them. All digit segments will turn on and display completely.
ZERO POSITIONING 1. Press the "B" button and all the segments in the digital time will reset to zero, with "UTC" showing in the main digital window. 2. Zero the "UTC" minute and hour hand (located in 12 o'clock sub-dial) to the 24 o'clock maker (straight up). Button "A" will move the hands clockwise, and button "C" will move the hands counter clockwise. 3. Press button "B" - "HR" shows in the main digital window. Adjust the main (large) hour hand to the 12 o'clock (midnight) position using "A" and "C" buttons. At the same time, observe the synchronized 24 hour hand (small dial to the left of the main dial), to insure that it also moves to point to "24". 4. Press button "B". "MIN" shows in the display window. Adjust the large minute hand to also point to the 12 using the "A" and "C" buttons. 5. Push the "M" (mode) button back in to its normal position. The watch beeps and at the same time the hands jump slightly. ALL RESET and ZERO POSITIONING are now complete. 6. Reset the time, calendar and other modes.
To set the time. Note that changing the time in any of the cities will automatically update the time for all the cities. 1. Press the "M" button to move the mode hand to (TME) 2. Press either the "A" or "C" button to move to the desired city. 3. Pull the "M" button out to the setting position. 4. Press the "A" button. SECONDS will blink. Set them with "C". 5. Press the "A" button again, and MINUTES will blink. Set them with the "C" button. 6. Press the "A" button again, and HOURS will blink. Set with the "C" button. 7. Press the "A" button again, and 12 or 24 hours tim format will appear. 8. Push in the "M" button to its normal position.
To set the calender 1. push the "M" button to move the mode hand to (CAL) 2. Set the city using the "A" or "C" buttons. 3. Pull out the "M" button to the "setting" position. The numbers of the "month" starts to blink. this is an "american" date system with the month first, day second, and year third. Use "C" button to adjust the month. 4. Push the "A" button. The date (day) will flash. Adjust with the "C" button. 5. Push the "A" button. The YEAR flashes. Adjust with the "C" button. 6. Push the "M" button back in. The calender is simultaneously adjusted for all cities.
Couple of other "tips".
Switching the time on the digital display with the time shown on the hands: 1. Press the "M" button until the mode hand is in (TME) or (CAL) mode. 2. Pressing the "A" and "C" button together. The time will switch the between the main hands (analog) and the digital display.
Temporary Hand Retraction Pressing and holding the "B" button will move the hands out of the way of the display. Repressing the "B" button will put the hands back at the correct time.
hope this helps. Source: how to set time on a bulova marine star 96C30
This solution is from fixya member ropickym Fixya
Jul 03, 2014 | Bulova Marine Star 96C30 watch
Instructions for the Rotary chronospeed GBO 3351/05 wristwatch
pull crown out to second position then keep pressing start button till it goes to 12 then push crown back in ,,
Dec 29, 2013 | Watches
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Casio edifice EF534D, The seconds hand does not come back to 00 on pressing the reset button. what is the problem, how do i solve it??
Have you solved this yet? I have a reset process that sets the starting position back to 12 o'clock. Pull the crown to the second (outmost) position and then start pressing the start-stop button repeatedly. Each push will set the starting position by 1 second, until you get to 12 o'clock, then push the crown back to its normal position. Let me know if that works.
Sep 18, 2010 | Watches
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
7. Push the lower right button back in.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
Reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Aug 28, 2009 | Watches
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
Kenneth Cole KC3081
if you pull the crown out to the #2 position,then push the start/stop pusheryou will move the sweep sec. hand up to the 12 o'clock position. push in crown. Don
May 22, 2007 | Kenneth Cole KC3271 Wrist Watch
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
How to Set Alarm
This is the movement used in the following Seiko watches..
SNAC74 SNAC75 SNA548 SNA694 SNAC40
SNAC41 SNAC42 SNA749 SNAC03 SNA411
SNA414 SNA765 SNAA03 SNAA05 SNAA01
SNAA02 SNAA61 SNAB61 SNAB62 SNAB64
SNAB65 SNAC25 SNAC29 SNAC35 SNAC36
SNAA61 SNAC38 SNA283 SNA695 SNAA30
HOW TO SET ALARM TIME
1. Pull the crown out to the second click position.
2. Press button “B” to set the alarm hour and minute hands to
current time.
3. Push the crown back to normal position.
4. Pull the crown to the first click position.
5. Press button “B” to set the alarm hour and minute hands to
desired alarm time.
6. Push the crown back to normal position.
Note:
Alarm setting on a 12-hour basis only. Alarm will ring at the
designated time for 20 seconds; one time alarm only. The alarm
needs to be reset in order to re-engage the alarm function.
HOW TO USE CHRONOGRAPH
1. Set crown at normal position.
2. Press button “A” to Start/Stop/Restart.
3. Press button “B” to Split/Split release/Reset.
HOW TO USE ALARM DIAL
AS DUAL TIME DISPLAY
2. Pres the button “B” to set the hour and minute hands to time of
a different time zone.
Nov 27, 2006 | Seiko Coutura SNA341 Wrist Watch
Watches Logo
Top Rotary Watches Experts
richie46
Are you a Rotary Watch Expert? Answer questions, earn points and help others
